Wisconsinwagen
If you hook up GALA you'll have speed sensitive cruise control. You can't hook GALA to the 26 pin connector if you're using the DFA wires because they use the same pins. GALA is not required.
01TDIMKIV said:Is it possible your antenna became unseated from the radio unit??
There are alot of crappy quality CD's being sold out there. If your Navi CD doesn't work when it's cold out, it's a piece of junk. It's got too many write errors. The CD media, CD writer or CD writing software isn't the best available. They all make a difference.BlueCTTDi said:is it possible the unit was too cold to read the CD?
tongsli said:There are alot of crappy quality CD's being sold out there. If your Navi CD doesn't work when it's cold out, it's a piece of junk. It's got too many write errors. The CD media, CD writer or CD writing software isn't the best available. They all make a difference.
Also, there is an info.txt file on each CD that you can read to see what version of Navteq's database you've got. Don't go by what someone tells your they are, ie 2005, 2006 or even 2007.
There are no 2007 disks out yet. It's always at least 6-months to a year behind. The latest version, 4B is dated to 2006. 3B, the version before that was dated 2005.
So if someone sells you 2007 maps, you're being scammed.
So I someone PM'd me that their ABS controller had a 27 pin plug. Looking at the wiring diagrams for a 1999.5 Jetta, it looks like it has a 25 pin connector on the ABS controller. Let's assume the pin count was off by two. DFA-L/R should be available from pins T25/12 and T25/21 (pins 12 & 21), respectively.Hoffer said:Now, I checked my A4 wiring diagram. On page six, we see that DFA-L and DFA-R are available on pins T47a/10 and T47a/8, respectively. In addition, the wire colors are green/white and green/yellow. It also says the wires connect in the instrument panel harness. I checked my ABS plug (remove the airbox, remove the little block wiring box, and you should be able to get to your ABS plug). Sure enough, pins 8 and 10 both had wires of the appropriate color. Now to find the other ends.
This was in a US 2003 MkIV Golf. Your mileage may very. But hopefully not too much!
I might be interested in the left coast stuff if the price is right. You thinking a 50/50 split on the set or a price per disc?Is anyone interested in splitting up a set of North American Version 7B CD's? I would only need the some of the east coast and am willing to sell off the rest. PM me if interested.
Have you hit up VWNavi yet?Thread resurrection. I've got some loose wires in the harness that connects my MFD to the car. Two wires which come from the TMC have popped out of the terminal block that goes into the back of the MFD. I can't for the life of me find the original instructions for the wiring. Can anyone point me in the right direction?
