Well the battery is completely dead (less than a year old). Car wont start with dead battery. It will start with a jump. The rough starts continued along with the stumbling and lights flickering as described earlier but just a few days ago i started it cold, drove about 2 miles, parked it, immediately tried to start it again and it just cranked and faded until it was dead. Today when the car is running after I jump it, Im getting 13.45v to 14.06v when i did about a minute long log on VCDS Lite. Pretty much the same with Multimeter on battery. About an hour later I did another quick VCDS log without car running and voltage had dropped to 10.41v
I realize if the battery is shot (even though its relatively new) it wont hold a charge. Its seems the alternator is working based on VCDS log and multimeter reading when car was running. Voltage did jump when car was started/jumped making me think the alternator is good.
I also got several codes with VCDS
VCDS-Lite Version: Release 1.2
Control Module Part Number: 1C0 909 605 F
Component and/or Version: 04 AIRBAG VW61 0202 0003
Software Coding: 12340
Work Shop Code: WSC 00066
VCID: 2721789FD6F5
1 Fault Found
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
1 Fault Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
1 Fault Found:
00778 - Steering Angle Sensor (G85)
00668 - Supply Voltage Terminal 30
00856 - Radio Antenna
36-00 - Open Circuit
One of the main things i suspect is that there is some sort of Parasitic Draining of the Battery going on. Recently my turn signals started acting up. Replaced the relay in the dash and problem solved. Shortly after that i heard the speakers crackling and popping when the car was off, radio was off and the key was out of the ignition. So possibly radio is killing battery.
Another idea is that the alternator is dead and or the voltage regulator. I did notice the multimeter briefly jumping around erratically with low readings right after i pulled the jumper cables and the car was stumbling like is has been (also might not have had good contact with terminals)...so maybe voltage regulator was acting up on cold starts but smoothed out after it warmed up
Sorry for long winded, possibly disjointed post but this has been driving me nuts. I dont have the best understanding of electrical issues. I'm mechanically inclined but not electrically. Ive checked most of the obvious grounds and connections and Ive done some basic tests with a multimeter and VCDS Lite trying to isolate the problem (Battery, Alternator, Voltage Regulator or Parasitic drain) and ive scoured this site and the rest of the interweb. Trying to figure this out before i have to take it to the shop. Luckily i have some time because the shop is backed up 2 weeks.
So far I haven't figured out much so any help is much appreciated
