Phillipw311
Okay so I have noticed ever since it got cold outside a few months back my car hasn't been right. It's got a shudder at an idle and won't hold a steady consistent 903 RPM. It's very erratic whether the motor is hot or cold. I need suggestions because it's giving me a hell of a headache. I am the TDI specialist in my shop and the only one that works on them and my own damn car is kicking my ass. Haha I know that's a common problem with manual trans ALHs with the DMF separating. But I have an 01M auto so that's not the case with mine.
Here's the headache part. It's contingent on ambient air temp. That's the factor. I realized when it warmed up a few days back, it had a smooth consistent idle. Next morning it was cooler so I fired it up. Idled poorly. And still idled poorly once the motor came up to 190°F.
I have VCDS and yes I've obviously started with and checked the basics. My IQ is high intentionally because I'm running DLC 764s and I want it lean. So when it's behaving and the values aren't bouncing all over the place, my IQ is set to 5.2-5.6mg/str. Under basic settings my timing is a HAIR retarded. By that I mean bouncing from 38-45.
Here's what I've replaced, done, and looked at over the past few months just throwing parts at it at this point because I don't know where to go with it since it's got me beat.
1.) ALL filters changed
2.) Crank sensor (genuine)
3.) Tried raising and lowering IQ. No luck.
4.) Replaced fuel temp sensor.
5.) Pulled pressure relief valve off pump inspected collar was a hair slid out popped it back in no change.
6.) checked for air in the fuel system. None.
I don't know what's going on but any input would be great because it's kicking my ass. Oh also I've noticed my EGTs seem higher when it's warmer and idles right and it boosts as should, but it feels gutless. Like it doesn't have the power behind it like it normally does. Crazy thing is when it is cold and idling bad, it's got twice the power (what used to be normal power until this began) the only thing that looks off to me on my measuring blocks is group 007. Fuel temp looks way too high to me. That's why I replaced it. Once it reaches 190°F the fuel temp is 38-46°C. I compared to another known good ALH and it matched right with the intake air temp within 3-5°C whereas mine are way off. So I think my thermostat T needs replacement I believe it has debris in it or is essentially simulating a stuck thermostat therefor causing excessively high fuel temps therefor retarding my timing.
*BUT KEEP IN MIND*, again it's ALL contingent on whatever ambient air temp is. Whether the motor is hot or cold makes no difference. That's what's got me stumped. That's why I don't that the Thermostatic T will do the trick. Because it idles rough cold too. It's also smoky when cold. With an IQ of 5.5mg/str it shouldn't be smoky at all at an idle. Again, being an auto it's got the fuel cooler so I think that's a red flag I don't think it should be that hot regardless. And yes I've checked my IAT (MAP) and it's accurate. So I'm at a loss. Somebody give me something it's driving me crazy. Haha thanks you guys.
