Old August 17th, 2002, 14:01   #1
MOGolf
MOGolf's Avatar
Default A4 TDI engine measuring blocks/groups
Based on the Bentley CD but includes other groups not documented there. Actual labels/values displayed may vary.
Group 000 measuring blocks
From left to right
Engine idle speed: range 42 - 45 = 870-950
Start of injection: range 12 - 75 = 2 degrees ATDC - 3 degress BTDC
Throttle position: 0 = 0 %
Injection quantity: 11 - 45 = 2.2 - 9.0 mg/stroke
Manifold Absolute Pressure
Atmospheric pressure
Engine coolant temperature: 80 - 35 = 80 - 110 degrees C
Intake Manifold Temperature: 182 - 50 = 10 - 110 degrees C
Fuel Temperature: 91 - 201 = 20 - 80 degrees C
Air mass: 69 - 111 = 230 - 370 mg/H
These are valid ranges only when the EGR is switched on, engine at idle and at least 80C (176F) coolant temp.
Group 001 (injected quantity)
Engine RPM: 870 - 950
Injected quantity: 2.2 - 9.0 mg/H
Modulating piston displacement sensor voltage: 1.450 - 2.000 V
Engine coolant temperature sensor: 80 - 110 C
If below 2.2 - injection is running too rich
If above 9.0 - injection is running too lean, or the engine is cold
If below 1.450 volts - injection too rich
If above 2.000 volts - injection is too lean, or engine is cold
Group 002 (idle speed)
Engine rpm: 870 - 950
Operating condition: 010
Engine coolant temperature: 80 - 110 C
Throttle should go 0 - 100 depending on pressure applied to "go" pedal
Operating condition left digit: 1 = idle increased because AC is on
Operating condition middle digit: Closed throttle position switch is closed (foot not on pedal)
Operating condition right digit: AC compressor switched on
Group 003 (EGR)
Air mass drawn in (specified): 230 - 370 mg/H
Air mass drawn in (actual): 230 - 370 mg/H
EGR vacuum solenoid duty cycle: 40 - 75 %
If air mass specified is above 370, engine too cold.
If air mass actual is below 230 mg/H, excessive EGR or an air leak.
If air mass actual is above 370 mg/H, engine is cold, insufficient EGR, or bad MAF sensor
(Note: EGR is turned off after approximately 2 minutes of idle. Reading should be within that time period.)
If a DTC is present, air mass actual will have a constant value of approx. 550mg/H over the complete RPM and load range.
Group 004 (Start of injection)
Start of injection (specified): 2 ATDC - 3 BTDC
Start of injection (actual): 2 ATDC - 3 BTDC
Cold start injector duty cycle: 3 - 80%
If start of injection (specified) is earlier than 3 BTDC, engine too cold.
If start of injection (actual) is before 3 BTDC, engine too cold, injection pump set too advanced, or cold start injector inoperative.
If start of injction (actual) is later than 2 ATDC, injection pump is set too retarded, injection adjustment blocked, or cold start injector inoperative.
Group 005 (starting conditions)
Engine speed
Starting quantity
This is not useful for troubleshooting.
Group 006 (test with ignition switch on)
Speed
Brake pedal monitor
Cruise control system
Cruise control system (indicates if activated, 0 = activated but switched off, 1 = activated, swtiched on, 255 = not activated)
Cruise control system left digit: Clutch switch closed (clutch not depressed) = 0, 1 = clutch depressed
Cruise control system middle digit: CC/DFI brake pedal switch open (brake pedal depressed) = 1, 0 = pedal not depressed
Cruise control system right digit: brake light switch depressed pedal = 1, not depressed = 0
Right cruise control system 6 digit display has a 1, left to right, when:
Clutch operated
Brake pedal operated
Resume speed operated on the switch
Acceleration operated on the switch
Cruise control and memory switched off
Cruise controll system switched on
Group 007 (Temperatures)
Fuel Temperature
Nothing
Air intake temperature
If the car has been sitting overnight (for example) these should all equate to approximately ambient air temperature. If not a sensor may be bad.
If fuel temp indicates -5.4C, there is a short circuit or the sensor is bad/inoperative.
If air temp indicates approx. 136.8C (275F) the air temp sensor is bad/inoperative. Check for a DTC.
If coolant temp sensor indicates a large deviation from ambient temp, there may be a short circuit or the ECT sensor is bad/inoperative.
Group 008
Injection limitation when warm/full throttle/3rd gear @ 3000 RPM
Engine rpm (2900-3100)
Injection quantity requested mg/R (40.0-42.0)
Injection quantity rpm limit mg/R (35.5-36.5)
Injection quantity MAF limit mg/R (36.0-39.0)
Group 009 (injection quantity limitation)
Engine rpm
Injection quantity (cruise control system active)
Injection quantity limit signal from automatic transmission controler during gear change
Nothing
Group 010
Air system warm/full throttle/3rd gear @ 3000 RPM
MAF sensor: 800-1000
Barometric pressure
MAP (boost): 1700-2080
Throttle position %: 100
Group 011
Charge pressure control warm/full throttle/3rd gear @ 3000 RPM
Engine rpm
Specified MAP: 1850-1950
Actual MAP: 1700-2080
MAP Valve DC: 45-95
Group 012
Glow Status
Glow period
Suply voltage from ECM
Not useful for troubleshooting.
Group 013
This group shows the smooth running control injected quantity cylinder 1 - 4, left to right. Values expected -2.0 - + 2.0 mg/R
This is showing how the ECM is balancing the power for each cylinder at idle to account for variations in component tolerances, jet sizes, compressions, etc.).
Group 015 (fuel consumption)
Engine rpm
Injected quantity (actual)
Fuel consumption
Injection requirement (as indicated by the go pedal)
Group 016 (additional heater)
Generator loading
Additional heater
Activation of heater elements
Voltage supply from ECM
Additional heater display is 8 digit number where, left to right, 1 =
nothing
nothing
ECT sensor inoperative
engine started within the last 10 seconds
engine speed below 870 rpm
battery voltage below 9 volts
generator inoperative
ECT exceeds 70 C-80C (158F - 176F), or intake air temp exceeds 5C (41F)
Activation of heater elements is a 2 digit number. Left digit = 1 when high heat output relay is on. Right digit = 1 when low heat output relay is on.
Group 017 readiness code
Not relevant
binary code: x000xxxx
Not relevant
binary code: 0xxxxxxx
These may represent ready (0) for "Comprehensive component", "Misfire", and "Fuel system" in the first code and "EGR system" in the second. I have not verified.
Group 018
Speed
binary bits: 00
nothing
nothing
Group 019 (Quantity adjuster)
Voltage from modulating piston displacement sensor: 0.500 - 0.970 V
Voltage from piston displacement sensor: 4.150 - 4.740 V
nothing
nothing
If specfied values are out of tolerance, possible malfunction of the injection pump quantity adjuster.
Group 020
Ignition timing
Absolute pressure
Speed
Load
Group 021
Fuel Temperature
Intake Air Temperature
Absolute pressure
Load
Group 022
Binary bits
Unknown
Binary bits
Binary bits
Group 026
An undocumented field
Groups 027-040
nothing in any field
Groups 041-079
Not valid
Group 080
Jibberish
Group 081-085
Nothing in any field
Group 086-124
Not valid
Group 125 CAN bus communiation status
Auto. trans. controller: Transmission 1
ABS status: ABS 1
Instrument status: Instruments 1
Airbag status: Airbag 1
Group 126-129
Group 130-255
Not valid
(edited to add undocumented-on-the-CD groups)
<small>[ February 20, 2003, 20:06: Message edited by: MOGolf ]</small>
MOGolf is offline   Reply With Quote
Old August 17th, 2002, 18:12   #2
daveyracing69
Fuel Economy: 53/43/39
Default Re: A4 TDI engine measuring blocks/groups
Nice job, I think allot of novice will use this. I know I took a look.
daveyracing69 is offline   Reply With Quote
Old August 17th, 2002, 18:41   #3
Harvieux
Harvieux's Avatar
Hi MOGolf, Very well done, my friend. This will assist many here, including myself. Later!
Harvieux is offline   Reply With Quote
Old August 18th, 2002, 07:01   #4
mjbach
TDI(s): 99.5 Golf
Fuel Economy: 45-50
MoGolf: What a great list. Just what we've been looking for and all in one post! Thanks so much.
mjbach is offline   Reply With Quote
Old August 18th, 2002, 08:57   #5
wolfsburg_de
Ross-Tech AssociateVendor
Fuel Economy: 33.5 mpg, mostly city
Great list!!! Any idea what the undocumented groups are?
I logged groups 008 and 011 on a 2001 Golf TDI and got some interesting fuel and boost readings.
wolfsburg_de is offline   Reply With Quote
Old August 18th, 2002, 15:24   #6
MOGolf
MOGolf's Avatar
With the aid of the latest VAG-COM, I have updated the list for the "missing" groups.
[ August 18, 2002, 18:57: Message edited by: MOGolf ]
Old May 26th, 2003, 16:15   #7
diesel des
Hi thanks for the info. I am haveing problems with trying the adaption in my car. I log in as 12233 and then want to mod the injection timing. I can mod blocks 1,2,3 and 5 but 4 the one I need says its not available. What am I doing wrong? I realise that this could damage my engine etc.. Thanks, Des.
diesel des is offline   Reply With Quote
Old September 13th, 2003, 19:51   #8
therabbittree
therabbittree's Avatar
TDI(s): B4 passat
what about "normal " setting s and "basic setting like in vw tool ? we just did a A4 t belt and using vw in basic setting group or block 00 for 2 and 9 the #2 block reads 0 seems very strange when i switch to "normal setting" it shows a value etc just not in basic it s getting frustrating ha we've adjusted the pump sprocket few times with no change in goup / block 2 from 0..any ideas? its pretty drastic you can have the engine run nice and smooth in normal then switch to basic setting and it smokes white smoke liek cray and idels much rough and stumbles a little so something is fishy...
thanks
deo
therabbittree is offline   Reply With Quote
Old December 15th, 2003, 13:58   #9
seaman_12
When I get my VAG-COM software next week, I want to perform a tune-up on my '01 Jetta. What are the optimum settings that I should use for this car such as idle speed, timing, etc? I assume these can all be set using the OBDII tool. Are these settings posted elsewhere on this board?
Thanks, Scott
seaman_12 is offline   Reply With Quote
Old March 16th, 2004, 21:02   #10
Nash_TDI
Veteran Member -TDIClub Enthusiast
Nash_TDI's Avatar
Fuel Economy: 63.25mpg max
Do you know anything else about measuring block 006. The second digit reads like it should and the third digit always reads 1 no matter if the brake is depressed or not. I have been having trouble forever.
Nash_TDI is offline   Reply With Quote
Old June 30th, 2004, 21:49   #11
04TDIPD
04TDIPD's Avatar
Just wondering.. I think my ambient sensor is screwy.. is there any way to tare it with VAG-COM?
04TDIPD is offline   Reply With Quote
Old July 28th, 2004, 16:45   #12
ukguy
we just did a A4 t belt and using vw in basic setting group or block 00 for 2 and 9 the #2 block reads 0 seems very strange when i switch to "normal setting" it shows a value etc just not in basic...
I am having exactly the same thing show up as above, did anyone come up with any explanation for this please. My engine is working fine apart from hesitant cold starts in the mornings!
Many Thanks,
Adam
ukguy is offline   Reply With Quote
Old November 16th, 2004, 13:32   #13
thortdi
Fuel Economy: 42/49/52
Hi,
is there any difference between the values
* "Air intake temperature" Group 7, Value 3
* "Intake Air Temperature" Group 21, Value 2
Or better, is there any Measurement block showing the temperature of the charged (turbo) and subsequently cooled (IC) air in the intake manifold ?
I would like to measure how efficient my TDI's intercooler still is.
Thanks !
thortdi is offline   Reply With Quote
Old November 16th, 2004, 18:14   #14
MOGolf
MOGolf's Avatar
They are the same reading.
There is no sensor between the turbo and the intercooler. Therefore the differential is not known.
Old December 1st, 2004, 16:34   #15
ScooterTDI
Are these the groups from an ALH or the PD? It looks like its from a PD.
ScooterTDI is offline   Reply With Quote
Page generated in 0.20602 seconds with 9 queries
[Output: 125.84 Kb. compressed to 105.63 Kb. by saving 20.20 Kb. (16.06%)]
