Well you could be right but I was always told that there were quality issues there that caused part of the work stoppages despite the labor strike, and perhaps it doesn't have anything to do with the cars here, 97-99 Mk3, but my 94 was lacking in assembly quality and the paint sucked badly, however, I've only ever examined a limited number of cars, maybe 100 at most in total both on the road and off, so I can't say that my sample size is large enough to evaluate quality, but if you're sure about it then I'll concede the point. The language barrier would be a huge issue, that I can agree with.I know about the labor issue in the early '90s. That really didn't have anything to do with the cars we are discussing. And having purchased five Volkswagens brand new (and PDI'd many others) I can assure you, Mexican assembly is at the very top of QC. The Puebla plant has actually won many internal awards. It was tasked with the rollout of the New Beetle in 1998, and was the ONLY place that ever assembled them, and they were sent back to Europe for retail sale (as well as some other models... like the original Beetle). Of my five new cars, all three of my Puebla cars were 100% perfect. Both my German cars (one from Emden, the other from Wolfsburg) had various QC problems. And for good reason. EVERYONE in the Puebla plant speaks Spanish. The German plants are a mix of languages and cultures, which only got worse after the fall of the Soviet Union. Prior to that, many Turks were employed in factories. After 1990, there were all kinds of folks. Hard to make certain something is being done correctly when there is a language barrier.
I have the former, but I've not seen the latter. I'm sure if it did in fact happen it would have to be after the beginning of calendar year 1997.I’m more curious to see an A3 with a 1Z engine or a B4 with an AHU, regardless of the trunk decal.
-Todd
Yes, my 97 Jetta has a 1Z in it and the decal is the same as that pictured (for engine and trans). The decal I pictured is from the first donor 98 Jetta engine that now resides in the B3V...and is AHU.I‘m a bit confused.... the Jetta pictured is a 1Z? Earlier, you mentioned the trunk decals in the Jetta’s were always wrong.
That's what I believe as well, unless someone produces a late production B4 with an original AHU in it...which no one has done yet AFAIK.if so, it jives with what I believed To be true. 1Z or AHU was a Jetta thing and B4s only came with 1Z.
-Todd
I tried to look in the ETKA online but they didn't differentiate between the two with the Mk3 in 1997, in fact I think it never made reference to the 1Z at all for 1997, just said AHU and that's it.If there's a VIN split on the engine parts that are unique to the 1Z (like the valves or pistons) you might be able to see it. I have ETKA 6 on an old Dell laptop, not even sure it'll boot up. But I could take a look.
You know it could be, the reference I use online shows no 1Z for Mk3 97, then again I've always wondered whether or not they simplify the parts listing in later years due to different / newer parts versions or consolidations.ETKA shows them together under JEM A3 cars. Engines listed as AHU/1Z (in that order), same as always. Two shortblocks listed, early and late, but are engine code numbers, both being AHU, and the first one with the M suffix supercedes to the late one with the AF suffix (both long NLA).
PAS B4 shows the exact same thing, only just the AF suffix... which is odd. Then you go to the B4 cylinder head page, and it shows an early and late, with a 1Z serial number listed, but on the right it just shows AHU.
I'll go out on a limb here and say the Mexican labor force had zero to do with ETKA anomalies. That's likely all Germans. Slipshod, perhaps?
