Camel413
- Joined
- Jun 22, 2010
- Location
- South East Missouri
- TDI
- 96 Passat Wagen Totaled, 95 Passat GLX future conversion
I just got my car back from the mechanic for its inspection to get my license sticker. In Missouri our inspections are pretty basic, check that the lights and horn works, tires are decent, suspension is ok and the windshield isnt cracked. No emissions testing.
Car was fine when I dropped it off. After picking it up when I shut it off and remove the key the dash goes completely blank. Before the miles and clock was still visible with the key out. Also every time the car is started the clock and miles reset. Another thing is the light on the dash for the open hatch is on even though the hatch is for sure closed. I have a gps and dash cam plugged into the cig lighter, neither of these will work now. I tested the volts on the lighter it is now hovering around 3 volts. I checked voltage across the battery with the car running and was getting 13.9 volts. Any ideas as to what could have happened at the shop to cause any of these issues?
