mickyTDI
- Joined
- Sep 21, 2003
- Location
- Longford, Ireland
Going through the measuring blocks on vagcom today i noticed a block that measures alternator load. Anyone know why the ECU needs to monitor this?
That's what i initially thought but isn't there an engine speed sensor that monitors the rpm.Sooch said:Just guessing here from my gasser tuning days. In order to keep a steady idle, at all engine loads, the ECU needs to monitor the alternator to sense when seat heaters, rear defroster, AC or even just the cooling fan come on. The ECU will add more fuel to compensate for the higher load and keep idle at 903 or whatever it's set at.
