sootchucker
Hi TDI Fam-
recently drained and refilled my cooling system. what a mistake....
i have used an airlift 550000 to fill my system... but i am still feeling like the system has air trapped since the car still runs hot at times. i have a VCDS and i was able to locate an informal procedure that bleeds the cooling circuit and then a second procedure that bleeds the low temperature circuit, found on this link.
does anybody know if this is accurate / or how in the hell to actually bleed this type of system?
thanks in advance...
Bleeding Cooling system on motor EA288
Hello , I will change my crankshaft and water pump on my audi A5 engine type EA288, and I would like to know the exact procedure to properly bleed the cooling system with my VCDS, it's necessary as Elsawin says. I have seen some explanations on the net, but often incomplete, or in languages...
forums.ross-tech.com
