SpeedFreek
How expensive is the harness, the same thing just happened to me.
There is a knob at the top of the boot where it connects to the car. You must press this up and pull outwards. The part of attachment to the door needs to be wedged out slowly if you are trying to remove the boot. I suggest just pulling the boot back to reconnect the wires. I ended up doing some custom fabrication and cutting to get the boot off.doggonit said:Hey, I have the identical problem with the drivers door...Mk5 (or 2006 Jetta TDI) ...I was suspecting the sensor indicating the door is open was disallowing allthe other functions to cease. My rubber boot looks just like this one... Now how do I get that boot off??
Doggonit in Mooresville, IN
I think it would be next to impossible to remove the boot on the door side without taking the outer skin off. The boot tapers into the wires inside the door and there is a strong seal inside. Looks much easier to pull the boot into the door...Maksymuik said:There is a knob at the top of the boot where it connects to the car. You must press this up and pull outwards. The part of attachment to the door needs to be wedged out slowly if you are trying to remove the boot. I suggest just pulling the boot back to reconnect the wires. I ended up doing some custom fabrication and cutting to get the boot off.
You can try disconnecting the battery for a few minutes to see if the airbag light will go out (I don't know - works on some cars?)kirkus said:Spent some time with help but got it done.
4 wires cut. Just used some extra wire with solder and heat shrink.
I worry about the other 5 that weren't broken.
I would've like to have had only one splice but don't think it's gonna be an off the shelf pin for the connector.
Of course this doesn't happen till late Friday and I've got a 1500 mile road trip starting Thursday.
Had some sparks coming from the clump of pooh.
Now I've got an airbag light and auto up on the drivers window doesn't work anymore.
It would be too nice of VGA to fix something like this. Even though so many of the cars functions go through the driver door. The wet interior doesn't make any nicer. Window wouldn't go up.
Thanks a bunch.You can try disconnecting the battery for a few minutes to see if the airbag light will go out (I don't know - works on some cars?)
To reprogram the auto window, Just put the window all the way down, hold down button for a few seconds, put window all the way up and hold button up for a few seconds. I don't think it matters which order you do it in- up or down first but i have done this several times with success.
I got the same (in Australia we have them made in South Africa) so it's a global issue:Spent some time with help but got it done.
The best advice I can give you is NOT to pry the top or bottom of the boot away from the door's A pillar. I broke my rubber boot at the top where an internal tilt-able latching tab is located. This was as a result of prying the boot away from the A pillar.Are there any directions how to remove the rubber cover to inspect the wires?
That is the method I used to fix my broken wire problem.^ same question...
Can the driver's door outer skin be taken off just by removing the bolts that are around the perimeter of the inside? Is there glue there that must be replaced?
It does seem that to remove the rubber boot at the door side that the boot must be extracted toward the inside of the door.
Can you tell me how you were able to get access to both ends of rubber boot without removing the door skin? I am very interested because one of my connections is not that great because I was not able to get back into the book on the door side. Any information would greatly be appreciated.I did mine 3 days ago. The ground wire was severed. With door wide open the two ends would not touch. I was able to get access at both ends of the rubber boot without removing the door skin. I first spliced the wire coming from the door and then ran that ~6" piece of wire though the boot and spliced it to the wire coming from the frame of the car (the plug). There was one wire that looked like it was going to go at any time and a tiny purple one that looked to have been severed for a while. I didn't have time to mess with them, but I plan on getting a new wire harness and replace the whole thing in the future.
After the fix, I now have an "Airbag Fault" light on. I'm not sure why, but as soon as my Vag-Com comes I hope to clear this code.
