300D
I am about to replace fans and do an AC overhaul. System is currently empty. I did an engine swap in December and I am hoping the compressor on the replacement engine is good. The old one had been neutered at some point in it's life and had the clutch removed(I think). I was going to do it all at the same time as the engine swap, but I could not get the lines off the AC drier for the life of me, and it was cold, so I gave up in order to finish the swap in a timely manner.
Can anyone point me to a writeup for all the bits and parts I should clean/replace? I have done ac system work in the past, so have a pretty good working understanding of it. Just want specifics to our mk4's. I have a vacuum pump I will put on it to test and prep with.
The parts I have so far are a new AC drier, new expansion valve, set of o-rings, and both fans. What else should I do while I am in there? Probably going to pull the front clip to get the best access.
Thanks.
Thanks.
