jhax
- Joined
- Jan 24, 2012
- Location
- Golden, CO
- TDI
- 96 Passat B4V, ALH engine out of a 2002 Jetta, some IE Rods and ASV Pistons. Nothing drivable yet though
Good Morning All,
I replaced my wheel bearing in my B4 last week and removed the knuckle from the strut. I am looking for a video or photos of the process of adjusting the camber. It looks like the wheels need to be on the vehicle and the vehicle needs to be on a flat surface. You then get under the car, somehow? Loosen the two strut bolts, and then what? Will the weight of the car automatically bring the camber back to 0? Do you roll the car back and forth with the bolts loosened? How do you get the car up high enough to be able to loosen the bolts in the first place and then tighten them back down?
Thank You,
Justin
Thank You,
Justin
