shortbus
There are 2 tutorials in the how-to. One specifically cautions *not* to bypass the fuel filter, and the other shows the car's fuel filter bypassed but a cheap inline filter used on the supply line from the DP container to the pump. Which is best? If I don't bypass the car's fuel filter, should I drain and prime the filter with DP (or replace and prime with DP) prior to doing the purge? Wouldn't there be a filter full of diesel diluting the DP if I didn't? I have a replacement fuel filter on hand, but if I prime it with DP and then run the purge, I'll have very little DP left in the can - might draw air? What about priming the new filter with Diesel Kleen and then running the full can of DP (diluted with Diesel Kleen) through the new filter 'til the DP's gone? Unfortunately I only have the one can of DP on hand...
