manual_tranny
Smyth Performance- Intern
YES, ABSOLUTELY! Less weight = more fun and better economy!!Pelican18TQA4 said:Only 2,600 lbs. and you think it needs to lose weight??
This is why more of you guys should be looking at the Smyth car build. You take your engine out of the front, put it in MR configuration. You can use the ALH motor so you have unprecedented economy and reliability. The final weight of the car will be in the neighborhood of 2200 pounds since you cut off so much of the car and replace the body with fiberglass.
The best part is that you get to do it all yourself!
(or you can ask me nicely... once I'm finished building mine I'll be happy to assist others and/or build your car for you...)
If you think you like 50mpg, just think how much you'll like 70mpg... because the lighter weight/reduced drag Smyth car will be easily capable of 70mpg, and I predict I will be getting 80-90mpg using pulse and glide... after fitting narrower tires running high pressure.
Take a look at the build pictures here on Facebook, I don't think you need to be a member or anything...
You can also check out the tdiclub Smyth Performance page by clicking on the link in my signature.
Smyth Performance Facebook Page
