LurkerMike
I think I read somewhere the 17/52 was a VNT-17 exhaust side and a VNT-22 compressor side. If this is so, then why is it called a VNT-17/52?
I really would like to make a custom silicone 90* hose to fit it that transitions to fit a 2" O.D. lower pipe (complete with internal grooves molded inside the hose to interlock with the hose barbs on the turbo outlet and custom lower pipe). A friend has this turbo and the over-stretched OEM outlet hose keeps blowing off, so I know there is a huge need for a properly sized hose (and lower pipe).
But I don't have a 17/52 (17/22?) Hybrid to model the hose on so I am hoping to get enough measurements to be able to make a "mock-up" 17/52 (17/22?) from a busted VNT-15. Once I have done this with plaster and clay, I will only need to verify (and tweak as needed) the model against a real car with a 17/52 (17/22?) installed. That car is over an hour's drive from me so I would like to do the verification step just once.
Can someone please measure the 17/52 (17/22?) hybrid's outlet like I am doing in these VNT-15 pics? I am about to miss the boat on this round of custom hose making mandrel molds which will delay this hose and lower pipe for weeks...
-This can even be done with the Hybrid on the car but pics would be helpful so I can replicate the measurements here with a VNT-15. Also I would need to know if the compressor was rotated some or is in the position it was shipped in.
Thanks!
Reposted pics:
First as the outlet relates to the exhaust manifold flange mounting plane (exhaust flange flat on flat surface and use that surface to measure from):
Second, from the centerline of the shaft to the end of the outlet:
On a side note, I think the KERMA 18XX Hybrids use the VNT-15's outlet... if this is so, then I will have them covered soon.
Thanks!
Reposted pics:
