I read about other people having a similar issue. When I drive my 2010 JSW TDI at more than 3 mph the odometer disappears and shows an exclamation point with the cruise control symbol next to it, regardless of whether the CC switch is on or off. No other issues or lights. I replaced the turn signal stalk with the same part number, put everything back together - same problem.
Does anyone have an idea what this could be? I don’t have OBD/VCDS, so unfortunately I can’t post a readout. Was thinking about getting a SWCU at the local U-Pull to switch it out, the contacts/pins where the turn signal stalk goes in look a little oxidized. Unless someone can point me in a different direction. Any help is greatly appreciated!
