Baby steps!
It would idel but wouldn't excelorate only idle?
This symptom raises the possibility that the injection pump is gummed up internally... perhaps as a result of sitting for 7 years with old diesel in it.
The throttle linkage controls an internal spring-actuated governor, which can seize in place over time... the "place" it seizes generally being idle.
Gunk can also seize the internal vane pump, making it hard/impossible for the pump to prime properly.
Some people have reported some luck filling the pump with ATF or lacquer thinner and letting it soak for several days, but often if this is the issue the pump will need to be disassembled and thoroughly cleaned.
Not a horrible job but it takes some time and attention, and since the pump has to come out of the car one needs the tools (dial indicator, adapter, locking jigs) to set the timing when the pump is reinstalled. If the car has been sitting for 7 years it should probably get a new timing belt anyways.
www.vwdiesel.net is the forum most IDI engine people hang out these days, and there are some threads there on pump disassembly, exploded diagrams, etc.
