I found 2 lower control arm bushing sets? [Lemforder 2713201] in a box and have no use for them. Can anyone identify them and does anyone have a use for them?
Hi,
You can have them if you pay postage. Is there a way to send them COD? To make sure these are the right ones the label says #2713201 009. I can measure them if you want.
Hi Again,
They look identical to the ones on ID Parts- rear bush -2.35" OD-1.6: long, front bush 1.4" OD and 2.1" long. Rear has metal sleeve inside and out, front bush has metal on inside only. I don't do pics.
Hope this helps.
Looks like those are correct according to my measurements.
Look at the top left side of this page where it says welcome vwdsmguy, underneath your name will be a private message link. Yours should show a bold 1 next to it. Click on that and the down arrow, then read new messages. I sent you my cell number so we can work out the logistics.
My PO receipt says they will arrive Wed 8/19 and the cost is $8.70. The tracking # is 9505 5121 6872 0228 1705 93 There wasen't a way to send it COD. I hope it all works out for you, but from reading the info on bushing replacment, good luck.
Sorry, I screwed up with the tracking # [2 numbers tranposed], but I see they were delivered today. Hope that's what you want. Time to send the postage. Frank Kline, 6817 Henderson Rd, Jamesville, NY 13078. Now all you have to do is install them. Better you than me.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
