control arm bushings?
vwdsmguy
Syracuse, NY
2002 Golf black 5-spd
I found 2 lower control arm bushing sets? [Lemforder 2713201] in a box and have no use for them. Can anyone identify them and does anyone have a use for them?
Tdijarhead
Lawrenceville PA
I need to replace these on my daughter beetle. How much do you want for them?
vwdsmguy
Syracuse, NY
Hi,
You can have them if you pay postage. Is there a way to send them COD? To make sure these are the right ones the label says #2713201 009. I can measure them if you want.
Tdijarhead
Lawrenceville PA
Measuerments would probably be a good idea, and maybe a pic to confirm we are talking about the same thing. Check your PM's
vwdsmguy
Syracuse, NY
Hi Again,
They look identical to the ones on ID Parts- rear bush -2.35" OD-1.6: long, front bush 1.4" OD and 2.1" long. Rear has metal sleeve inside and out, front bush has metal on inside only. I don't do pics.
Hope this helps.
Tdijarhead
Lawrenceville PA
Thanks I'll double check tonigt when I get home.
Tdijarhead
Lawrenceville PA
Looks like those are correct according to my measurements.
Look at the top left side of this page where it says welcome vwdsmguy, underneath your name will be a private message link. Yours should show a bold 1 next to it. Click on that and the down arrow, then read new messages. I sent you my cell number so we can work out the logistics.
vwdsmguy
Syracuse, NY
I mailed them at the post office
My PO receipt says they will arrive Wed 8/19 and the cost is $8.70. The tracking # is 9505 5121 6872 0228 1705 93 There wasen't a way to send it COD. I hope it all works out for you, but from reading the info on bushing replacment, good luck.
vwdsmguy
Syracuse, NY
parts for your suspension
Sorry, I screwed up with the tracking # [2 numbers tranposed], but I see they were delivered today. Hope that's what you want. Time to send the postage. Frank Kline, 6817 Henderson Rd, Jamesville, NY 13078. Now all you have to do is install them. Better you than me.
Tdijarhead
Lawrenceville PA
Thanks Frank. It’s always enjoyable to speak tdi with another enthusiast. I’ll get the postage out in tomorrow’s mail.
