roadhard1960
When I change the oil in my John Deere 870 (28 hp Yanmar) the oil comes out black. When I add fresh oil and a new filter I start up the engine for a few minutes and then let the oil level settle. The oil still looks new.
I drive my 2003 up on ramps. I drain the oil by removing drain plug. I remove the filter. I get out the MityVac and suck a few ounces (almost 4) out of the oil filter housing. I install the plug. I dump a few quarts through the filter housing to fill up those passages I sucked out. I then top off the normal way. I start the engine and drive off the ramps. I check the oil and it is black. So where is all that black oil from in the Jetta that I do not see/get in the JD? Granted the JD only has 300 hours in 10 years while the 2003 probably has 3,000 hours but even when the Jetta was new oil changes were like that. Black after just a few minutes of idle.
Does draining the oil when the car is level result in more oil drained? Do the cam buckets hold that much oil? I know my Toyota 22RE cam buckets hold a fair bit of oil but like blood, a little can seem like a lot. Next oil change I will nerd out and try to get the car level before I finish the oil change. I will also remove the cam cover to see what quantity of oil can be sucked out.
Last oil analysis showed no signs of oil issues if you ignore the fact that the air filter was not properly installed and was letting in excessive dirt. Shame on me. I may never hit a million miles if I do not do better air filter changes. TBN of 6. 10,000 miles on sample.
