El Jimador
Hi,
I have this weird noise in the car that started around September. I have a 2005 Passat TDI Wagon, Auto trans (i wish it was manual), anyways, when i checked it with my friend (he used to work in Germany as a certified VW mechanic) to see what the noise was. First he told me to change the belts as it was the cheapest option. That didn't fix it. After further inspection, we realized (or thought) that it was the alternator belt tensioner with the hydraulic dampener that started to go. As we saw the damper leaked and it was stiff. I went to the local shop and changed it. The noise stopped on cold starts but then comes back when the car warms up. I went back to the shop and he said it's the balance shaft chain tensioner. But instead of replacing the whole thing because it would cost a lot, he asked me to see if i could find just the chain tensioner and chain for the BSM instead of deleting/replacing it. I was just wondering if you guys know where i could get just those parts? Or if you have any thoughts?
Thanks,
Jim
Thanks,
Jim
