cfunderburg
I can't loosen the 4 dampner bolts because the dampner keeps spinning! I've tried with the belt back on and everything just spins. How do I lock the dampner in place so that I can get the bolts out?
Use a large socket, extension, and a breaker bar on the crank bolt to keep the crank from turning while you loosen the damper bolts. You will be applying torque to the crank in the clockwise direction while turning the damper bolt in the opposite direction. Also, if you don't already have the RH front wheel off, that helps get direct access to the damper.cfunderburg said:I can't loosen the 4 dampner bolts because the dampner keeps spinning! I've tried with the belt back on and everything just spins. How do I lock the dampner in place so that I can get the bolts out?
Here are my notes regarding this: http://www.myturbodiesel.com/1000q_how_to/a3b4/passatchrip.htmredmondjp said:Use a large socket, extension, and a breaker bar on the crank bolt to keep the crank from turning while you loosen the damper bolts. You will be applying torque to the crank in the clockwise direction while turning the damper bolt in the opposite direction. Also, if you don't already have the RH front wheel off, that helps get direct access to the damper.
Yeah, they've gone through the roof...all the way up to $65.49!GeWilli said:they aren't $60 anymore...
