She is lovely. the CC is more curvy then the passat, The CC looks good.
i hope you did not just make the same mistake I did when I trade my JSW for a BMW 135, I wanted fast and sporty.
The fast and sporty did wear out quick. Specially the hars handling of the tight suspenson. Every time I had to cross a rail road track I gently lifted my but off the seat to reduce the shocking/jolting effect. Every body wanted to race against it, most lost.
one reason I gave it up in favor of the passat TDI was, and this is the major reason:
I had to fill the BMW with premium gasoline and it averaged 20-22mpg. was a frequent visitor at the pump, forking out the cash for primo gasoline.
i actually was limiting my driving due to the fueling budget. While drivng the BMW was lovely, I was grinding my teeth every time... knowing I could have taken my wifes jetta TDI and burn half as much fuel.
Given that the diesel here in Texas is about same as the premium gasoline my fueling cost is cut in half.
I actually want to drive, or should I say I don't mind driving.
I will see you back in a little bit .... mate
