metallica21156
Was getting a intermittently stall. Was always able to restart the car. Found it was common for the crank sensor to go out. Last week while driving it died at highway speed. Cars a 5spd. Noticed oil pressure warning was also on the dash. Restarted the car and kept going. Later it happened again and noticed no rpm reading. Got the car home with no more issues. Swapped out the sensor and now its worse. Sometimes i can get it to start. Will run for a few minutes and die. Also have gotten it to restart with no rpm showing on the dash but once again oil pressure alarm. Checked the wiring harness and repaired rubbed spots and repaired as needed. Still seem to be having this issue.
