@kpiazzisi:
Mine is a Canadian 2006 TDI with Climatic. My manual says
22 Fan (40)
23 Front Power Windows (30)
24 Cigarette Lighter (25)
If it was me, I'd replace the Fan fuse. For the voltage question: have you cleaned the grounds on your car? A weak point on 2006s. From an old post:
Grounds:
"The main ones
- Under the wiper arm / cover in the cowl area
- Under the air box on the left front frame rail behind the headlight
- The one next to the battery
- One more on the passenger frame rail behind the headlight
I usually wire brush clean all surfaces then spray with a liberal coating of Dexoit."
If you have climatronic, you might want to re-read post 6 in this thread about canbus and the perils of making 12v jumpers.
There is also a known problem with the fan blower resistors. See thread
http://forums.tdiclub.com/showthread.php?t=375202 . The underlying cause is the fan motor, which blows the fuse, or the resistor. If you pull the fan motor (not hard to do, lots of good how-tos here), and clean and lube it, the problem probably won't recur (for a while) once the fuse or resistor is replaced. You could also replace the motor, but a few drops of oil and a half hour works for me. I relube the fan motor every 18 months - it's a poor design, motor before the filter, so it gets dirty. Which reminds me, I'm due to do it right about now. Off to the passenger footwell...
