higgledy
I am going to buy a roof bike rack for my '14 VW Golf 5-door. Does anyone know how for-mounted bikes I can get on the VW-branded roof rails? Thanks
follow the instructions for the bike rack.I am going to buy a roof bike rack for my '14 VW Golf 5-door. Does anyone know how for-mounted bikes I can get on the VW-branded roof rails? Thanks
Remembering you have a bike on the roof is important, no question.I'm surprised nobody mentioned the possibility of forgetting that the bike is on the roof and pulling into the garage, with unpleasant results. Hey, it happens. Work a long day, go for a ride after work, run a couple of errands on the way home, and forget the bike is up there. Been there, done that.
However, a bike hanging off the back bumper of a JSW in the rain is getting rinsed with the crap that winds up on the back of the car. Hey, it happens.
x2, been there. I now use a Saris rack I picked up for $40 when transporting more than one bike, but prefer to have the bike worth nearly as much as my car stored inside my car.I'm surprised nobody mentioned the possibility of forgetting that the bike is on the roof and pulling into the garage, with unpleasant results. Hey, it happens. Work a long day, go for a ride after work, run a couple of errands on the way home, and forget the bike is up there. Been there, done that.
My bike is worth way more than my car, and with two of them on there it's more than double. One of my bicycle tires costs more than my car tires as well.x2, been there. I now use a Saris rack I picked up for $40 when transporting more than one bike, but prefer to have the bike worth nearly as much as my car stored inside my car.
I like the hitch rack better too. In fact, I own a really nice Thule hitch rack that I use on the minivan. I do not like the look of a hitch on the Golf. Plus, a hitch will limit ground clearance on a car that already sits low to the ground. This is important because I have a steep driveway, I don't want to scrape the road every time I come home or leave.I would go with hitch type. It's easier to use then lifting you bike on the roof.
I've done that too. But I can only get one bike in my hatch without risk of scratching the bike or my interior.I note a lot of people with bikes on a rack, either on top or on back, with plenty of room to put the bike INSIDE the car. Particularly with JSWs, since I drive one, but also with Golfs. I know you can fit a 60 cm road bike with the front tire removed in the back of a Golf. No MPG hit, no grime on the bike, and you're not advertising that you're going on a ride & will be parking your empty car at a trailhead.
The problem I have is not grime on the bike, but getting bike grime on the inside of the car. Chain lube will never come out of an interior, not to mention black marks from the tires when/if the bike shifts in transit. With 2 bikes there is an increased risk of unintended derailleur adjustment or bike contact.I note a lot of people with bikes on a rack, either on top or on back, with plenty of room to put the bike INSIDE the car. Particularly with JSWs, since I drive one, but also with Golfs. I know you can fit a 60 cm road bike with the front tire removed in the back of a Golf. No MPG hit, no grime on the bike, and you're not advertising that you're going on a ride & will be parking your empty car at a trailhead.
there's an easy solution. moving blankets used to protect furniture.The problem I have is not grime on the bike, but getting bike grime on the inside of the car. Chain lube will never come out of an interior, not to mention black marks from the tires when/if the bike shifts in transit. With 2 bikes there is an increased risk of unintended derailleur adjustment or bike contact.
remove chain from bike.Moving blankets would work. But so does a bike rack.
I have 6 bikes and bike often, so you'll have to show me how to clean a chain so it doesn't have anything on the outside that can stain. Negating the mountain, fat, and cyclocross bikes of course, because mud is just a way of life for those.
You must of missed the part about chain maintenance after the ride..Not to get too OT, but 'wipe clean' is a misnomer. Been there, done that. The chain lube comes out of the rollers and re-coats the chain. The only chain lube that doesn't get everywhere is a chain wax, which dries, but it doesn't work for crap up here because it's a dry lube.
Here in California some folks with hitch racks have gotten tickets because the rack obscures the rear license plate, even tho there were no bike on the rack.
Just sayin'....
You'd have to have a pretty weird hitch rack for it to obscure the plate on either my mk3 or our Mk4. My strap on rack on the other hand rested directly on the plate.
I also use an ultrasonic cleaner to get my chains clean. Really clean. On some I'll ultrasonic the lube into them, then hang for a few days and keep wiping off the excess, but it's only for the road bikes with tight tolerance (and expensive) chains.
Riding and living with mud in Maine is a way of life. It is impossible NOT to get muddy in the woods. We even have a season for it, called "Mud season". We avoid riding the trails in mud season due to damage but there is mud all year due to the topography. many of the trails have just opened this week and more are still closed pending dryer conditions.
I am a trail volunteer and have my own bike shop, so I'm all set on the rocket science.
Right after winter. We don't get many tourists during mud season and it's tough enough for the locals to get around.@Abacus When is Mud Season in Maine? Do you get many tourist?
The Westfalia hitch loses NO ground clearance. PF Jones also has suitable bike racks.I like the hitch rack better too. In fact, I own a really nice Thule hitch rack that I use on the minivan. I do not like the look of a hitch on the Golf. Plus, a hitch will limit ground clearance on a car that already sits low to the ground. This is important because I have a steep driveway, I don't want to scrape the road every time I come home or leave.
