I need a gasket between enhaust manifold and turbo, but the dealer says there is no listing, the turbo comes complete with manifold?! Anybody has any solution to this? Old gasket is gone...
Yep, no gasket. Lots of exhaust components are like that when it is cast iron on cast iron. Most of your old Detroit Wonder Metal engines had no gaskets between the head and exhaust manifolds.
Mine had a cheap chinese turbo on it when I bought it, and there was a gasket put in place between the manifold and turbo. I am guessing that it's not causing and issue, but I can assure you that mine has a metal gasket there.
