Alberta 7.3
Looking for some input. I'm planning on a BHW for a RWD diesel conversion project. Is it possible to delete the tandem pump for firewall clearance and use a high pressure supply pump with a regulated return to feed the PD system? I've read that the tandem pump supply pressure varies with engine RPM, would a constant pressure screw up injection quantities at lower engine speeds? I don't need the vacuum pump since the vehicle will have hydroboost brakes, and a small electric vacuum pump supplies the climate actuators and whatever vacuum the engine would need for solenoids/actuators.
I've done a forum search and came up empty handed
