ghohouston
So yesterday, as I finished up my timing belt job and injector change, it came time to try and start my car. I started out just cranking the engine with glow plugs out to try and bleed my injector lines with low strain on the engine. After a while, I realized I wasn't getting the fuel spurting from the lines, as usual. I put the trans in 5th with the wheel off of the ground and spun the tire quite a bit with no luck. I then removed the main suction line from the fuel filter outlet fitting, and pulled a vacuum through the filter. Found it has lost quite a bit of diesel from the injector lines being removed, and the car sitting for a few days. I got diesel coming through the filter quickly as expected. So go back to the mentioned methods of priming with no luck. I then removed the #4 injector return line to the pump, and pulled vacuum through it, for like 20 minutes, with no luck. Even spun the tire again while vacuum was being pulled, and this still didn't do much.
At this point, I said there has to be a much better way. I removed the 17mm nut off of the return fitting on the injection pump, removed the return banjo fitting that the #4 line tee's into, and finally removed the banjo bolt fitting from the pump. With the banjo bolt fitting removed, I found exactly why these cars are so hard to prime this way. That fitting has a check valve in it, as well as very small orifices for the return fuel. I then took a piece of 3/8 fuel line cut straight, and just stuck it up against the threaded return port of the pump, and pulled vacuum through it. I had the pump primed almost immediately.
Short version, for easy injection pump priming, remove the 17mm nut off of the return fitting on the end of the pump. Then remove the banjo fitting that is connected to the return lines. Then remove the actual banjo return fitting bolt that goes into the pump. This is the 17mm hex just against the pump housing. Then pull a vacuum through this. Fuel will come very quickly, compared to the rest of the methods I've found on these cars.
Figured this could help save many many people hours of headaches. I wish I would have taken pictures.
