A5INKY
Done lots of searching and reading on this and other forums and still wrestling with this issue.
Car is a 2006 Jetta TDI 5MT (MKV) with a bad battery drain issue. Started by charging and disconnecting the battery, will hold a charge for days disconnected from the car so the battery is fine. Then began with a VCDS scan that is showing only one pertinent DTC, 00470 Combination Comfort Databus in One Wire Mode. Measuring blocks show the CAN gateway will not go to sleep due to this assumed broken CAN wire somewhere. Following TSB 27_08_04 I checked the fuses and found fuse #15 for that module is pulling around 100mA after the door switch is fooled closed and the interior lights go out like normal. That one circuit is pulling way more than the >40mA the whole car should consume at rest. This makes sense considering the CAN gateway will no go to sleep.
Going with the most likely causes, the radio and driver door wiring harness, I first made note that neither had any DTCs set. Unplugging either will cause the CAN gateway to not see that controller (or radio) but will recognize them again as soon as plugged back in. Both are behaving normally and a physical inspection (as much as can be seen) of the harness to the driver door shows no damage to the wires in the normal breakage spot.
Before I post the VCDS Auto Scan results, I will ask if anyone can guide me on the next step for troubleshooting?
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K56M772309 Mileage: 213580km/132712miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H02--- Serial number: VWZ7Z0F3301482
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CCA1B8A7BA063E1F5-8031
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000512070290
Coding: 0000020
VCID: D1A2F86C48080396C43-8084
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71E2D8EC6848A396643-8024
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 EB
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 68D4B5885B92625E33D-803D
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000260671
Coding: 14010E234004180000140000001400000008730B5C
Shop #: WSC 05074 444 58638
VCID: 2A500F80851E904EE59-807F
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 05074
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 39 AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD04236B
Coding: 0013113
VCID: 397220CC70B82BD69C3-806C
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0D3C666BS
Subsystem 3 - Serial number: 6342MSME0D6E072FT
Subsystem 4 - Serial number: 6351HSME091D44110
Subsystem 5 - Serial number: 6361HSME09144135
Subsystem 6 - Serial number: 63727SME086C4D036
Subsystem 7 - Serial number: 63827SME09064156Z
1 Fault Found:
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
009 - Open or Short to Ground - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0010021
VCID: 78F4E5C80B32F2DEA3D-802D
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 L
Component: KOMBIINSTRUMENT 3HL 4312
Coding: 0023203
Shop #: WSC 05074 444 54671
VCID: 336E12E452D4D18656F-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105C14A511
Coding: 3F3F0B40071002
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 213581 km
Time Indication: 0
Date: 2000.00.00
Time: 02:16:22
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 36682BF041A6C4AE711-8063
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: A_ KSG 0401
Coding: 137803087F09058F880F048051A0
Shop #: WSC 34340 001 1048576
VCID: 74ECD1F8175A96BE8F5-8021
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 377626F446AC3DA66A7-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7F6030627
Coding: 0040400
VCID: 2142E8ACF8285316B43-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 316218ECA8C8E396243-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 326017E0ADCED88E5D9-8067
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5A049CB4F0877600B-8078
End ---------------------------------------------------------------------
I found a TSB for the airbag DTC, looks like a high connectivity resistance under the passenger seat that the TSB is guiding the tech to wire around the questionable connector. I don't see that causing this. The DTC for the steering angle sensor is likely from having had the battery disconnected. A recalibration once the issue is resolved should take care of that - again, thinking that is not going to pertain to the battery drain either.
Thanks in advance!
- Is it possible to have a fault, say in the driver door, that is still recognized by the CAN gateway but has a broken wire or bad module? Perhaps I still have a broken wire buried in the driver door I just cannot see (old bellows style doesn't give much room to look) and the remaining single unbroken wire is enough for the door latch to report back to the CAN gateway?
- Anyone see a central electronics control module go "bad"? Seems unlikely, just odd that every single module is reporting in fine but the DTC for one wire mode is still present.
Coding: 0050078
Coding: 0000020
Revision: 00H13001
Coding: 0021122
Coding: 00063445
Shop #: WSC 05074
Coding: 0013113
1 Fault Found:
Coding: 0010021
Coding: 0023203
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 74
Mileage: 213581 km
Time Indication: 0
Date: 2000.00.00
Time: 02:16:22
Coding: 0001269
1 Fault Found:
000 - -
1 Fault Found:
Coding: 0001269
Coding: 0040400
Coding: 0000144
Coding: 0000144
Thanks in advance!
