replaced the throttle body unit.... no change. Car still low power mode. same codes.
Tried to do output test on the MAP sensor... there seems to be no option to do so.
Throttle adaptation does nothing at all. No output, no sound from unit.
Visually inspected every fuse in the car....none blown
Visually inspected wiring that I was able to see and trace... nothing broken/loose/corroded/or falling apart.
Tried to test connector with multimeter, but frankly, I am unsure of the proper process to test a connector across the pins.
All other functions in car work fine...(lights, power stuff in the interior, windows.....)
Latest full scan below.
Monday,20,December,2021,14:40:52:42997
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: 3VWRL7AJxxxxxxxxxxx License Plate:
Mileage: 246710km-153298mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 62 65 72
77
VIN: 3VWRL7Axxxxxxx Mileage: 246710km-153298miles
15-Airbags -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 K HW: 03L 906 022 TS
Component: R4 2.0l TDI G001AG 9983
Revision: 12H03--- Serial number:
Coding: 0050078
Shop #: WSC 23303 444 85640
VCID: 364DC40841E08839AB-8062
VINID: 0E69E270745A1D17411011C2105AFB2326
3 Faults Found:
008449 - Throttle Valve Actuator Control System
P2101 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 246719 km
Time Indication: 0
Date: 2016.05.12
Time: 00:35:28
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.16 V
Lambda: 99.4 %
Bin. Bits: 00000000
000568 - Manifold Pressure / Boost Sensor (G31)
P0238 - 000 - Signal too High - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 246719 km
Time Indication: 0
Date: 2016.05.12
Time: 00:35:29
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.16 V
Pressure: 1004.3 mbar
Pressure: 2190.1 mbar
Temperature: 2.7°C
Temperature: 13.5°C
008450 - Throttle Valve Actuator Module (J338): Motor Circuit
P2102 - 000 - Signal Low - MIL ON
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 246719 km
Time Indication: 0
Date: 2016.05.12
Time: 00:35:29
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 99.4 %
Mass Air / Rev.: 0.0 mg/str
Temperature: 60.3°C
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 052 T HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9037
Revision: 51112 Serial number: 00001003252070
Coding: 0000020
Shop #: WSC 00066 000 00000
VCID: 256F1344EC46F3A112-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B400C492600FB881202E6921D0042310000
VCID: 7AD51038F578AC590F-802E
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00147
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 75CF0304D466C32162-8020
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 085 G HW: 5K0 937 085 G
Component: BCM PQ35 B++ 111 2129
Revision: BI111001
Coding: 25200B3E902F3EE4800800854000000401000086510085605C8020000000
Shop #: WSC 41850 001 1048576
VCID: 3753C90C86EA7131B0-8062
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 26051 23 0512
Coding: 009795
1 Fault Found:
02092 - Enabling Heated Seat
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 8
Reset counter: 213
Mileage: 246713 km
Time Indication: 0
Date: 2016.05.12
Time: 16:35:30
Freeze Frame:
Term 15 On
Voltage: 13.65 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AD HW: 1K0 909 605 AD
Component: 04 AIRBAG VW8R 036 8900
Revision: 06036000 Serial number: 003EVM02Z4VD
Coding: 0012340
VCID: 6EFD2C687930F0F9A3-803A
Subsystem 1 - Part No: 1K0 959 339 H
Component: BF-Gewichtsens. 007 0006
Subsystem 2 - Serial number: 6332MSME51660F1FK
Subsystem 3 - Serial number: 6342MSME50356017%
Subsystem 4 - Serial number: 6351HSME2129494DB
Subsystem 5 - Serial number: 6361HSME21050033P
Subsystem 6 - Serial number: 63727SME2061356C
Subsystem 7 - Serial number: 63827SME20611D47
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001731
VCID: 76CD04080160C8396B-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5M0 920 970 G HW: 5M0 920 970 G
Component: KOMBI H05 0305
Serial number: 00000000000000
Coding: 271F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 3449FE009F9C9A2995-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 080510F2002169
Coding: ED807F07400612001002
VCID: 69F75F7440DE17C1F6-803C
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6AF520788DD81CD9FF-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667917019
Coding: 010000
VCID: 266D14485140F8B91B-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H06 1000
Revision: AB001001 Serial number: VWZ6Z7K6102078
Coding: 040004000400008600
Shop #: WSC 23303 444 105071
VCID: 236B0D5C22720D917C-8076
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 35
Reset counter: 213
Mileage: 246672 km
Time Indication: 0
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0000868789
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 2773194C5E4AE1B120-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000004892847
Coding: 000490
1 Fault Found:
66048 - Motor for Front Window Regulator
B11EC 54 [008] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 2
Reset counter: 253
Mileage: 246673 km
Date: 2021.12.20
Time: 00:44:50
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 3147F714A88EAF01FE-8064
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0000890424
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 28711A705354EEC929-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000004924807
Coding: 000490
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 253
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 35
Reset counter: 213
Mileage: 246672 km
Time Indication: 0
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 111 0821
Coding: 018705
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial number: 00000005243855
Coding: 0013077
VCID: 3A55D03875F86C594F-806E
End-------------------------(Elapsed Time: 02:16)--------------------------
