Stealth TDI
Pre-Forum Veteran Member
Hello,
I just finished my first fuel filter replacement. The dealer did the one at 20k. I had them let me inspect the fuel filter housing before installing the new filter. In retrospect, I wonder what I would've seen if I had looked before the original filter was removed. Anyway, I opened my fuel filter, surprised to find the fuel under pressure and squirting everywhere, and didn't see any flakes. Then I shined a light in and could just BARELY make out flakes:
Here's a zoomed area of the same photograph:
As I said, I could barely see anything. I think I'm getting old when I have to snap a photo for a better look. I couldn't see any flakes once the black background of the fuel filter was removed. I swapped filters, primed with VCDS, and then started her up.
This is really discouraging! How long should I wait before taking it to the dealer? I think if I take it too soon then there won't be any flakes for them to see. What should I expect? Will VW clean/replace everything if the HPFP hasn't completely failed? Will they cover it ALL under warranty? When do I cut my losses with VW and go for the CP3/2micron conversion?
I was slightly hesitant when I bought the car, but opted to follow the advice of "drive more, worry less." Now that I have this just two weeks after Dieselgate, I'm a bit peeved. And I have TWO of these cars!
I appreciate your thoughts. I know there are plenty of threads about the HPFP, too many, actually. But I wanted to start my own thread to document my personal case with VW, just in case I have any trouble.
Thanks,
Scott
Thanks,
Scott
