Why would a 2260 making 30 PSI with an engine at 18.5:1 compression make less power than the same turbo running 35 or 40 PSI on an engine with 16.5:1 compression? Isn't it about how much charge you get into the chamber and how much you compress it? My numbers may be wrong, but I'm sure you understand the question. Even if you're not running it at the edge of its efficiency curve (or beyond) it may still keep the air charge and EGTs cooler, which will also help power.
I'm not arguing here, this is just something I've tried for a long time to understand and haven't gotten a good explanation.
