ChippedNotBroken
MOVING ON TO OTHER THINGS. CAR SOLD.
As noted below in the spec's, the car currently has a 17/22 turbo.
Now that Matt Whitbread has finished the fabrication and installation of my 2260 it seemed appropriate to start a thread. Pictures will follow. Below is a pretty comprehensive list. I will use screen names to describe board members who were a part of this build. Whitbread did most of the fabrication and the installation of the drive train and breathing mods. 87turboquattro (Wild Bill) ported and polished the head, mrchill is responsible for the pistons and TDIJetta99 (I am lucky enough to live about 10 miles from Jason's shop) has done the suspension, lift pump and everything else before and after the build.
Of the big parts the turbo was purchased from IndigoBlueWagon, the engine and transmission from BleachedBora and jsrmonster is programming the car.
PD150 Block (BleachedBora)
Rosten Rods
Standard PD150 pistons (replacing on 5/27/13 Custom Ceramic coated Pistons w/gapless rings (mrchill))
P/P Head w/dual springs (90# seat) and titanium retainers (87turboquattro)
Colt Stage 2 Cam and hardened lifters
17/22 (IDI parts)5/27/13 obtained in a trade of my unused GTB2260vk from (RyanP) Original build was GT2260v which ran till 5/27/13
6 speed DRW w/upgraded Shift Fork (BleachedBora)
DS3 Clutch w/17# single mass flywheel (BleachedBora)
Peloquin LSD (BleachedBora)
11mm pump
RC tune (jsrmonster)
lift pump (TDIJetta99)
fuel cooler
Nicktane FF (ndamico)
Changed to R520 from Nicktane .260 Nozzles (ndamico)
Custom Intake (Whitbread)
replaced with 17/22 on 5/27/13 Custom Header for 2260 turbo (Whitbread)
2.5 FMIC piping (Whitbread)
3” SS exhaust following were removed ... w/cat and resonator (Whitbread)
PSD08 Powercore Filter - customized
Koni FSD’s (IndigoBlueWagon)
AUDI TT suspension overhaul (BleachedBora)
80 Duro Dogbone (IndigoBlueWagon)
Shine Springs (IndigoBlueWagon)
225/50/16 Continentals on 16” Fitapelli wheels
Slotted brake Rotors
Changed back to 3bar with turbo change 4 bar MAP sensor (RyanP)
Old Navy CCV
Bypass Oil filter
boost and EGT gauges
Battery replace with standard battery Optima D31A Yellowtop (in trunk)
Fabrication Materials
Tubing, vbands, resonator, etc...
Silicone and t bolts
Battery cables and fuse
Battery box
IC core
Misc engine build parts
Machine shop work to Hone and balance
Bolts from fasteners
Antifreeze, lower rad hose, heat wrap, hose clamps, fluids
Fitting, lines, and fuel cooler
Replace after failure with standard rings Total seal rings
The next question everyone asks is "How much did this cost?" A better question in my case is where did the money come from, since I ain't got this kinda money.
We all know the stock market crashed back in September of 2008 and hit bottom in March of 2009. I figured that if things got any worse my money wouldn't be worth anything anyway so I begged borrowed and squeezed every penny I could find to buy American stocks like IP, CAT, X, BGS etc...
After more than tripling my original investment I paid off the loans, put some money into a sepIRA, paid my taxes and started this build. It's a good thing that the majority of the work is done since that money is now gone and now I'm on my own dime. Hopefully my wife will find a new job in the next few months so I can polish off the last few experiments on my car and see what it can do on the track next year.
Sold Nov. 8th, 2014
Rosten Rods
11mm pump
fuel cooler
Old Navy CCV
Bypass Oil filter
Battery box
IC core
Sold Nov. 8th, 2014
