TDIJetta99
ooph... bad news indeed... I guess it's time to make the Mini faster...
the retainers are titanium,not the springs.springs are dual spring w/ 90lbs on the seat.standard set up for that spring.What are the deets on the valve springs?
Thanks Wild Bill, I updated the OP to reflect the correct stats.the retainers are titanium,not the springs.springs are dual spring w/ 90lbs on the seat.standard set up for that spring.
I think the shine kit does make the car look a little funny (sitting so front end high), but it handles really well....
First impression, these things really raise up the front of the car. I haven't measured yet, but it looks to have raised up the front by about 1.5 to 2 inches while lowering the rear of the car.
while there is still way too much lean in the front end of the car for comfort on fast turns.
It doesn't sit level at all.. it actually looks like a stock ALH automatic with the transmission out of it.. We didn't measure it last night, but it looked like about 5-6" of wheel gap in the front, and about 3" in the back.. Definitely too high in the front..I think the shine kit does make the car look a little funny (sitting so front end high), but it handles really well.
Still too much body roll in the front end? I'm running shine/billy HD's/shine rear bar/stock front and my opinion is that it barely leans at all. Of course everything is relative.
I'm curious if yours actually does lean more.
I'm with Scott I have bilstein HD shocks and struts with a rear o-bar. I had shine springs and the car was flat as a pancake to me and handled extremely well. I went back to stock springs though because I enjoyed my plusher ride. Car has a little more roll but still handles really well.I think the shine kit does make the car look a little funny (sitting so front end high), but it handles really well.
I'm running Shine 4 cy springs with FSD's. he springs raised my front 1 1/2" to 5 1/2 at the back of the skid plate. It's not as high as yours. The car sits near level. I like how it handles with the FSD's. It's much better on the curves than when I got it. It wasn't totally stock then either.Jersey
Measured from the ground to the base of the frame the front is a little over 1/2" higher than the back. Not exactly what I was expecting. The alignment was off by more than 2.5", got that fixed this morning and drove the car around for about 2 hours. Smoke has improved (meaning less smokey) but still no where near legal in any state.
The suspension is still squirrely in hard turns. The alignment helped, but did not cure. I am not ready to give up on the shine/FSD combo just yet, but need to find a cure for the height in front and the body roll on the front wheels in hard turning situations.
Been told to expect a tuning adjustment for Dyno day. Can't wait!
I know that images never come up for me either. I have to log in a second time when it tells me I can't see them because I am not registered.Interesting to see it tomorrow. I am one of the many people who are locked out of the images site so I can't see the larger pictures. But it looks about right for the VR6 springs. The 4 cylinder springs would cause it to sit about 1/2" lower in the front.
The battery is about 60lbs lost from the front, but the 6 speed is just about 65 pounds heavier than a 5 speed. PD150 bottom end is negligible, and lsd is maybe 5-8 pounds more than the stock diff. Skid plate is maybe 20 lbs total. All in all, no major change.I may have mis-calculated the additional weight in front. The missing battery and mounting hardware was at least 60# out of the front. The skid plate, 6 speed, LSD and PD150 bottom end must not have added as much weight as I had calculated based on figures I gleaned off the site.
I don't understand why anyone would go with a one size fits all shock with a non-spec spring combo. Unless you have a cup-kit, get a adjustable dampening shock so you can match up with the spring rate.
Part of the reason I started this thread is to document the learning process. I may start a thread about all the mis-steps and screw-ups that got me to where I am now - hoping that others will learn from my mistakes. I read alot of threads on this and other forums, got a lot of conflicting advice, sometimes with all the noise it is hard to glean the facts. Right or wrong, I didn't get the adjustable damping strut because I was told that even on the softest setting that they were very harsh, right or wrong, that was the reason. I am not unhappy with the combination I have if I am able to solve the roll issue with the correct sway bars. Am I going down another dead end path, possibly, but suspension is such a subjective subject that I have found it almost impossible to make a "fact based" choice.The battery is about 60lbs lost from the front, but the 6 speed is just about 65 pounds heavier than a 5 speed. PD150 bottom end is negligible, and lsd is maybe 5-8 pounds more than the stock diff. Skid plate is maybe 20 lbs total. All in all, no major change.
What motivated you to take off the sleeper hubcaps ?
As posted above it was a little more than I expected based on driving my wife's Mini which weighs about the same and puts out over 175 HP. I suspect the reason i underestimated the max HP on the jetta is that my MAX hp band is smaller than hers and the twin turbo on the mini starts pulling sooner so it feels like it has a little more power over a broader range.man I would've sworn that thing would have put down more than 205.. What did it do for torque numbers?
That was with the stage 4's, we had a few unexpected issues that prevented us from getting the new Nick's in. Wouldn't that be cool if bigger Nicks smoked less205 is a good baseline . With that much unburnt fuel going out the tailpipe, there's definitely another 20-30hp easy left in that combo. Was that with the injectors I sent you or your stage 4's?
Yep kinda just what it feels like when in the car. Hopefully you can get that thing spooling up sooner to get a little bit more drive-ability down low.
Since I was expecting about 185 I am pleased with the 205 as a baseline. Your numbers are great I'm wondering how many issues cropped up getting there and how you resolved them?I hope well seated rings will solve the mystery. By all rights, you should be out pulling me by a comfortable margin. As it is, your whole curve fits under my last one.
There were several issues related to getting the tune right. Having one of the last BEW's, my car has an unusual software that confused things for my tuner. The first issue was simply turning off the CEL & codes related to removal of the EGR solenoids. Then there was the issue of keeping power up while reducing smoke mostly at the top end. Now it appears the big bottle neck has been the stock TIP & other air inlet parts. A larger intake is now in place & I'm waiting on a refined tune to take advantage of it. Oh, in hot weather my SMIC seems to limit the top end as well. That is far more evident on a dyno than on the road at speed.Since I was expecting about 185 I am pleased with the 205 as a baseline. Your numbers are great I'm wondering how many issues cropped up getting there and how you resolved them?
