Did it! Love it!
Fricking awesome! Both kids were asleep, the sun was still up, the wife was okay, and I had a few minutes alone with the car, FUEL SENDER MOD TIME!
Tank was a little under half full so the "lower bowl" of the fuel sender was full but I just tilted it and let most of the fuel drain back into the tank. I had a paper towel to catch the drips and an oil catch pan ready to put the sending unit into... no mess!
Once the unit was out and in the pan the FIRST thing I did was to remove both wires from the level sensor track connectors so that I could leave the lower bowl (which still had fuel in it) in the pan and take just the very top plate with the two tubes off. Sweet! No mess again!
Found a tight fitting drill bit and it only took a few slow turns to destroy the white plastic tri-pod seen when looking from the top... then I took a coat hanger and started fishing... I got the spring out no problem but the black rubber flapper, which is much bigger than the tube, seemed to be able to "hide" in a wider part in the middle of the tube where it used to seat with its spring... I didn't use any compressed air, just blow hard with my lungs from both ends. And the coat hanger to fish the spring only slightly twisted and black rubber flap in one piece! I highly recommend going slowly and only just breaking the plastic tri-pod using a few turns of a clean drill bit so that you can remove the spring and round rubber flap in one piece, less worries that way.
I was kindof nervous and in a hurry so I reget not taking pictures nor hooking up a vacuum pump and gauge to check the amount of vacuum required to break the check valve... I did do the suck test and there was alot of resistance to air, image how much to fuel! Not any more!
So the test drive! Fricking awesome! My car has 296,000 km and is mostly stock except for PSI powerbox, and egr valve that won't open (oh well, scanguage clears the CELs when they appear), and a new VNT actuator that is adjusted for quick spool up on the stock VNT15). Power used to plateau at 3500, but after drilling out the fuel sender: the power builds smoothly right up to red line! Remindeds me of when she was brand new! You can really feel it in second and third gear, revving it up is fun again! Also, even at 2000rpm the throttle seems more responsive and even less turbo lag it seems!
I have a butt-dyno from this March, when the fuel was probably thicker. My car ran alot better when the weather got up over 15 degrees celcius, so I suspect this mod will really pay off next winter when the fuel gets thicker. When I get a chance I will run the butt-dyno again, but for now I've penciled in my perception of the difference in my car...
Also the old dyno pull was in 2nd gear, sampled at .8 samples per second that is not really much data, but you get the idea... power used to plateau at 3500rpm... as I have illustrated using mspaint now it pulls right to redline!
Thank You AndyPandy for reviving this mod for 2008! Fricking awesome! Also thanks to folks who did the other threads, I read every one I could find on tdiclub and the payoff today was fantastic! Oh by the way, I had the "D" revision part number in my 2001.
