delvey
Hi, having some issues with my car starting. My 1.9TDI turns over but won't start. I had a load of fault codes (intermittent) and it feels like it is trying to start. I have noticed on my other Mk4 golf (130bhp) you can hear the pump kick in when the ignition is first turned on. Should I experience the same with the ALH? If not, how do I test? Voltmeter across the connector?
Also, when using VCDS and trying to run 035 under the engine, I get an error. Does this indicate it's buggered?
