chaloux
Sweeet. Oil pan, oil pan plugs, rod bearings and bolts, and oil pickup all arrived today. Time to get to work!
Some people operate better under tight time constraints. Even though I prefer not to operate under said conditions, I tend to put myself in that position more often than I'd prefer to. Get your ducks in a row ahead of time so you're not stalled by parts MIA. I think you can do it. Please keep us informed of your progress.I will be documenting pretty much everything with the wiring out of necessity - I'll need to figure out *** happened in there at some point in the future I'm sure!
I officially have a "finish date" - August 23. I NEED to have this car done and on the road by then, because I'm committed to going to //Sfest in this car! I'm bringing my son and I need to look cool in front of all the other //festers for him
Where did my list go.... ah, there it is:
- complete mounting
- swap engine harness/wiring/cluster/ECU/MAF
- swap go-pedal from the bug
- figure out fuel lines
- intake and exhaust
- plumbing: oil, water, A/C
Doable? I think so
Awesome! What are you going to use it on? I'm sure Hank already mentioned that an exhaust housing in the .8 A/R range will be best for that thing... you could even try a .6 if you wanted to help spool even more. Regardless I'm still curious to see what someone can do with that turbo on this side of the ocean.Way to go, sounds like you are making some good progress on it. I ended up with your dad's old comp turbo, but that's a different project for a different day.
The 6465 as a single turbo conversion would be pretty damn sick. Full boost at 4500 (use a QSV and it'd be below 4k!), 650whp, 35+psi.... hells yeah.I have a 2.7tt motor that I'll be putting rods into for a semi-budget big single v-6. I want to find a clean B4 90Q to put it into and run it on E-85.
I haven't really started anything yet, I need to get my TDI Audi finished up before I start another project.
Use a 04-05 passat tdi starter. It bolts onto the 01E just fineNeed some help re: the starter. We tried to fire it up today only to realize that the 2.2L AAN starter is nowhere near strong enough.
SO after some researching, I figured that a 1.9L TDI Quattro starter should work - if it's quattro it should be the 01E right? Any advice would help. My dad just picked up a 2.5L 5cyl TDI A6 Avant but that starter is HUGE, two inches longer and much larger diameter. I can't fit one like it in with the engine mount that I have now, so I figured a 1.9 TDI A6 or A4 would work.
I just need it to bolt into the 01E and be strong enough.
If you plan on using cruise control you will need the clutch switch. If not then you can get away without it.The Audi didn't have a clutch safety switch - is this part of the ECU?
