Dim00sivtec
- Joined
- Oct 4, 2015
- Location
- Portland, Oregon
- TDI
- 1998 Beetle TDI manual, 2002 Jetta TDI converted to manual, 2006 Jetta TDI Manual
CLeaning out the garage, need to move these parts.
ALH Block - usable, no scratches on the cylinder walls, 120k miles - $350
ALH Crankshaft - usable in good condition - $330
crankshaft brackets - $30 for the set
Monsoon head unit (missing knobs), amplifier, 4 speakers, 2 triangle tweeters - $65
Automatic Transmission module (01M 927 733MD) out of 02 Jetta TDI - $175
Passenger side airbag (out of 03 Jetta wagon) - $50
Alternator out of 98 Beetle TDI - $75
ALH valve cover - $45
Left engine bracket- $35
Left engine mount - $35
Right engine mount - $35
Dog bone mount $30
Oil filter housing - $50
Injection pump sprocket - $25
Window motors - $30 each, I have all 4 corners
TDI ECU 038 906 012 GN - $175
Brake booster - $40
ALH Cam sprocket - $25
TDI Manual instrument cluster out of 03 jetta wagon TDI manual - $100
ALH vacuum pump - $35
ALH TDI Auto starter - $50
ALH alternator bracket - $75
Sunroof motor - $30
ABS pump - $50
Driver side airbag out of 03 Jetta - $50
Cruise control arm - $15
Wiper control arm - $15
Battery fuse box out of 03 Jetta TDI manual - $15
EGR valve not cleaned - $25
Intake manifold not cleaned - $35
EGR Cooler - $45
EGR piping - $45
Power steering pump - $35
Steering column - $50
ALH Crank sprocket - $25
Coolant reservoir tank - $15
Borg Warner VNT17 turbo (brand new, has not even seen a mile of use, has only been installed, then removed as found out engine needed rebuild) - $750
Oil pump - $35
Oil pickup - $25
Windshield washer reserve tank - $15
Drive axles out of 02 jetta tdi auto, have drive and passnger $45 each
Cooling fans - $35 each
AC Compressor - $50
ALH timing cover plastics - $35
Turbo piping - $55
Injector brackets - $20 for all 4
I have photos of all items listed, will send on request.
Feel free to make offer, but please be reasonable.
Prices are without shipping, any shipping charges will be paid by buyer. Free for pickup in the Portland, OR metro area
Dog bone mount $30
Brake booster - $40
Sunroof motor - $30
ABS pump - $50
EGR Cooler - $45
EGR piping - $45
Oil pump - $35
Oil pickup - $25
AC Compressor - $50
Turbo piping - $55
