pillpusher84
Hi all,
I am fairly new to the forum and VW as a whole. I picked up this US-Spec 2015 Jetta MK6 TDI SE w/ Connectivity Package. The vehicle has push-button start OEM from the factory, however it is very frustrating that the car does not have keyless entry. I need to remove the key from my pocket, hit the unlock button to get into the car. Very weird for a car that has push-button start to not have a proximity sensor to allow the door to unlock when the driver's handle is pulled.
Is it possible to add this to my vehicle? Does anyone know what is necessary? I assume an antenna and possibly a door handle (not sure if a different door handle is used in VWs, or just proximity antennas?)
I do have a VCDS Cable & the latest software from Ross Tech, as I am also in the process of converting from Halogen headlights to OEM BiXenon Headlights. Thats another story (what a time I have had trying to find the correct wiring diagrams for this 2015 Jetta and my OEM CECM, which is fully capable of BiXenons!) ... but I finally found it (erWin didn't even have it).
I'm pretty sure I have a KESSY module on this car (see AutoScan below), but assume I would need to have it in order to have remote start, so hoping this is a relatively easy mod, which would simply require a new driver's door handle, additional antennas, some wiring and possibly some VCDS coding
I look forward to any help anyone here can offer me! Thanks
Code:
Chassis Type: AJ (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77 0B
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 906 016 AK HW: 04L 907 309 K
Component: R4 2,0L EDC H20 8276
Revision: 8AH20---
Coding: 011D0012042410085000
Shop #: WSC 00066 790 00014
ASAM Dataset: EV_ECM20TDI01104L906016AK 001008
ROD: EV_ECM20TDI01104L906016AK.rod
VCID: 72C52DCAA5EC44B168B-8027
1 Fault Found:
4481 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 061 T HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4508
Revision: 05653104 Serial number: 00001408270082
Coding: 0000020
Shop #: WSC 02069 000 90108
VCID: 256F0696ECA263093D9-8070
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: A14B400C492800FF851302ED921C0042A1100012
Shop #: WSC 00066 790 00081
VCID: 04297B1287587A014A7-8051
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0349126476
Coding: 000F0F
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSYPQ35G_AU21.rod
VCID: 3753DCDE8E0EE1999F5-8062
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CA HW: 5C0 820 047 CA
Component: J301 Klimaanlage 0207
Revision: 2001001S Serial number: 00000002464433
VCID: 61E75286B80ACF29011-8034
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 E HW: 7H0 937 090 A
Component: BCM PQ25 Max3 H78 0725
Revision: B8078001 Serial number: 78003321140909
Coding: 7B994BBA08AB0B0008382080340894CD0F86702E60000050B0A050022844
Shop #: WSC 00066 011 00000
VCID: 3041E7C2636036A1DEF-8065
Subsystem 1 - Part No SW: 6R0 959 801 AN HW: 6R0 959 801 AN Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 5461
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AS HW: 6R0 959 802 AS Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 5461
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H10 0007
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H04 0019
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 M HW: 6R0 959 811 M
Component: J388__TSG_HL 006 5460
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 M HW: 6R0 959 812 M
Component: J389__TSG_HR 006 5460
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 AB HW: 5C0 959 655 AB
Component: AirbagVW10 500 0975
Serial number: 003LZD03HHXD
Coding: 00004B33
ASAM Dataset: EV_AirbaVW10SMEVW360 001030
ROD: EV_AirbaVW10SMEVW360_SK35.rod
Seat occupied recognition:
Subsystem 1 - Part No SW: 4M0 959 339 A HW: 4M0 959 339 A
Component: BF-Gewichtss. H05 0016
Serial number: IBH0000J140001QEAH09
Coding: 303345
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME6A493D49ZZZ8
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME75493D49ZZZ5
Crash sensor for side airbag; rear; driver side:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME5C386E31ZZZ+
Crash sensor for side airbag; rear; passenger side:
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME77681E32ZZZ
Crash sensor for front airbag; driver side:
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Fahr H02 ----
Serial number: 3556LSME7D4E4031ZZZ/
Crash sensor for front airbag; front passenger side:
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME7F427731ZZZ+
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5C6 920 954 A HW: 5C6 920 954 A
Component: KOMBI H04 0807
Serial number: 00000000000000
Coding: 270801
Shop #: WSC 00066 011 00119
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 2C79F3B247485241E27-8079
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090 A
Component: GW-K-CAN TP20 H78 0725
Revision: B8078001
Coding: 102200
VCID: 70C127C2A3E076A19EF-8025
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0807
Serial number:
Coding: 000007
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
VCID: 6AF535AA8D3C8C71D0B-803F
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000305635003
Coding: 4900000000000000
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3041E7C26B6036A1DEF-8065
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 306 3501
Revision: 00H22000
VCID: 3957DAE6701AF7E9691-806C
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 188 H HW: 1K0 035 188 H
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3637534
Coding: 01000440020006
VCID: 2D7FFEB674525B49F59-8078
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 9
Reset counter: 163
Mileage: 3066 km
Time Indication: 0
Date: 2015.04.11
Time: 12:15:36
Address 75: Telematics (J949) Labels: None
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140529
Coding: 02630102C2163A007F1606000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_OCULow 001010
ROD: EV_OCULow_SE12.rod
VCID: 538B884E3AB62DB983D-8006
1 Fault Found:
2103041 - Control Module
B1788 F0 [009] - Start Prohibition Deactivated
Freeze Frame:
Fault Status: 00000001
Fault Priority: 8
Fault Frequency: 1
Reset counter: 126
Mileage: 7062 km
Date: 2015.05.18
Time: 15:50:41
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 E HW: 5N0 035 729 E
Component: TELEFON H07 0593
Revision: 1B001001 Serial number: 00007666828147
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 3245EDCA656C04B1A8B-8067
End-------------------------(Elapsed Time: 02:38)--------------------------
