Adding Keyless Entry to 2015 Jetta TDI SE w/ Connectivity
pillpusher84
NJ
2015 Jetta TDI SE Connectivity Package
Hi all,
I am fairly new to the forum and VW as a whole. I picked up this US-Spec 2015 Jetta MK6 TDI SE w/ Connectivity Package. The vehicle has push-button start OEM from the factory, however it is very frustrating that the car does not have keyless entry. I need to remove the key from my pocket, hit the unlock button to get into the car. Very weird for a car that has push-button start to not have a proximity sensor to allow the door to unlock when the driver's handle is pulled.
Is it possible to add this to my vehicle? Does anyone know what is necessary? I assume an antenna and possibly a door handle (not sure if a different door handle is used in VWs, or just proximity antennas?)
I do have a VCDS Cable & the latest software from Ross Tech, as I am also in the process of converting from Halogen headlights to OEM BiXenon Headlights. Thats another story (what a time I have had trying to find the correct wiring diagrams for this 2015 Jetta and my OEM CECM, which is fully capable of BiXenons!) ... but I finally found it (erWin didn't even have it).
I'm pretty sure I have a KESSY module on this car (see AutoScan below), but assume I would need to have it in order to have remote start, so hoping this is a relatively easy mod, which would simply require a new driver's door handle, additional antennas, some wiring and possibly some VCDS coding :)
I look forward to any help anyone here can offer me! Thanks :)
Code:
Chassis Type: AJ (6N0)
Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 44 56 75 77 0B
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CVCA)       Labels: None
   Part No SW: 04L 906 016 AK    HW: 04L 907 309 K
   Component: R4 2,0L EDC   H20 8276
   Revision: 8AH20---
   Coding: 011D0012042410085000
   Shop #: WSC 00066 790 00014
   ASAM Dataset: EV_ECM20TDI01104L906016AK 001008
   ROD: EV_ECM20TDI01104L906016AK.rod
   VCID: 72C52DCAA5EC44B168B-8027
1 Fault Found:
4481 - Cruise Control Switch (E45)
          P0568 00 [032] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-927-770.lbl
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4508
   Revision: 05653104    Serial number: 00001408270082
   Coding: 0000020
   Shop #: WSC 02069 000 90108
   VCID: 256F0696ECA263093D9-8070
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: A14B400C492800FF851302ED921C0042A1100012
   Shop #: WSC 00066 790 00081
   VCID: 04297B1287587A014A7-8051
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 E    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1202
   Revision: 00092000    Serial number: 0349126476
   Coding: 000F0F
   ASAM Dataset: EV_KESSYPQ35G A02717
   ROD: EV_KESSYPQ35G_AU21.rod
   VCID: 3753DCDE8E0EE1999F5-8062
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 CA    HW: 5C0 820 047 CA
   Component: J301  Klimaanlage   0207
   Revision: 2001001S    Serial number: 00000002464433
   VCID: 61E75286B80ACF29011-8034
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090 E    HW: 7H0 937 090 A
   Component: BCM PQ25 Max3 H78 0725
   Revision: B8078001    Serial number: 78003321140909
   Coding: 7B994BBA08AB0B0008382080340894CD0F86702E60000050B0A050022844
   Shop #: WSC 00066 011 00000
   VCID: 3041E7C2636036A1DEF-8065
   Subsystem 1 - Part No SW: 6R0 959 801 AN    HW: 6R0 959 801 AN  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  006 5461
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AS    HW: 6R0 959 802 AS  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  006 5461
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Coding: 180000
   Subsystem 4 - Part No SW: 6C0 959 442 A    HW: 6C0 959 442 A
   Component: E221__MFL-TAT  H04 0019
   Coding: 280000
   Subsystem 5 - Part No SW: 6R0 959 811 M    HW: 6R0 959 811 M
   Component: J388__TSG_HL  006 5460
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 M    HW: 6R0 959 812 M
   Component: J389__TSG_HR  006 5460
   Coding: 800000
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD03HHXD
   Coding: 00004B33
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360_SK35.rod
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140001QEAH09
   Coding: 303345
   Crash sensor for side airbag; driver side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H02 ----
   Serial number: 3572MSME6A493D49ZZZ8
   Crash sensor for side airbag; front passenger side:
   Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H02 ----
   Serial number: 3582MSME75493D49ZZZ5
   Crash sensor for side airbag; rear; driver side:
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H02 ----
   Serial number: 3516KSME5C386E31ZZZ+
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 5 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H02 ----
   Serial number: 3526KSME77681E32ZZZ
   Crash sensor for front airbag; driver side:
   Subsystem 6 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Fahr  H02 ----
   Serial number: 3556LSME7D4E4031ZZZ/
   Crash sensor for front airbag; front passenger side:
   Subsystem 7 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Beif  H02 ----
   Serial number: 3566LSME7F427731ZZZ+
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5C6 920 954 A    HW: 5C6 920 954 A
   Component: KOMBI         H04 0807
   Serial number: 00000000000000
   Coding: 270801
   Shop #: WSC 00066 011 00119
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
   ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
   VCID: 2C79F3B247485241E27-8079
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 7H0 937 090 A
   Component: GW-K-CAN TP20 H78 0725
   Revision: B8078001
   Coding: 102200
   VCID: 70C127C2A3E076A19EF-8025
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0807
   Serial number:
   Coding: 000007
   Shop #: WSC 00066 000 00119
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6AF535AA8D3C8C71D0B-803F
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305635003
   Coding: 4900000000000000
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041E7C26B6036A1DEF-8065
Address 2E: Media Player 3
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   VCID: 3957DAE6701AF7E9691-806C
Address 56: Radio (J503)       Labels: None
   Part No SW: 1K0 035 188 H    HW: 1K0 035 188 H
   Component: Radio Prem-8  H07 0009
   Revision: -----12S    Serial number: VWZ4Z7P3637534
   Coding: 01000440020006
   VCID: 2D7FFEB674525B49F59-8078
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 9
                    Reset counter: 163
                    Mileage: 3066 km
                    Time Indication: 0
                    Date: 2015.04.11
                    Time: 12:15:36
Address 75: Telematics (J949)       Labels: None
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140529
   Coding: 02630102C2163A007F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 001010
   ROD: EV_OCULow_SE12.rod
   VCID: 538B884E3AB62DB983D-8006
1 Fault Found:
2103041 - Control Module
          B1788 F0 [009] - Start Prohibition Deactivated
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 8
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 7062 km
                    Date: 2015.05.18
                    Time: 15:50:41
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007666828147
   Coding: 0A10030080010110
   ASAM Dataset: EV_UHVUMI 001007
   ROD: EV_UHVUMI.rod
   VCID: 3245EDCA656C04B1A8B-8067
End-------------------------(Elapsed Time: 02:38)--------------------------
vtbigdog
Vermont
2012 Jetta TDI DSG
You mentioned keyless entry...and then remote start. Two completely different animals.
It was my impression that keyless entry was included with Kessy, so I'm wondering if the door handle unlock is just not working properly for you.
You can check this by removing the keyhole cover and using the key, cycle the windows up and down a few times. Then try touching the handle to see if it locks or unlocks. If this does not work then...
mmn
BC, Canada
2015 Jetta TDI 6MT Sportline
In the mid level 2015s (SE in U.S. and Comfortline in Canada), they've created this middle of the road KESSY called KESSY GO. Which means you have remote start with the ignition button, but not keyless automatic door entry. I have the exact setup you're talking about on my new 2015.
And I don't believe there's any way to modify it from what I've found online.
Old Radar
San Antonio, TX
2015 Jetta TDI SE w/Connectivity
Pillpusher--Welcome to the club! That's the Under-enthused Fob Users Club!
tj pointed you to the thread I started several days ago. Discussion there seems to have dried up. Most of the old heads don’t believe it can be changed or, having guzzled the Kool-Aid, don’t think it’s necessary. I’m new enough to VW and still stubborn enough to die of thirst before I reach for the Kool-Aid to believe it is possible. It’s still pretty much a faith thing because, sadly, I don’t have a shred of technical info to back that up.
pillpusher84
NJ
Thanks ... I actually saw your thread before I posted this, however I also misread what you stated that you wanted the system to do, and therefore why I posted this thread.
I do not think the KESSY GO is what is in my 2015 TDI SE w/ Connectivity Pkg. I have checked a full auto-scan of a TDI SEL and compared the hardware to my 2015 SE Connectivity and it is the EXACT SAME hardware, but with different coding values set.
The only hardware difference that I can tell is different driver's and front passenger door handles that have the sensor and additional antenna built-in in the SEL vs. my SE. This leads me to believe that I can swap the door handles on both front doors, and wire up the 4 pins in each door handle to the KESSY ECU which is in the steering column area of the dash, and then change the coding to match the 2015 Jetta TDI SEL.
I have already coded and physically added an RNS-510 Navi, LED Tail Lights and BiXenon Headlights successfully to the car (Total Cost $1500 USD) ... so if I can add the keyless entry handles as well .. I will be very happy, and would have saved a ton of money by not being forced to purchase a SEL trim-level, and will have a Much nicer navi and LED Tail, which are not available on any MK6 TDI Jetta.
See wiring diagrams for J518 Acc/Auth ECU (address 05 in auto scan): http://bmwesys.com/jetta/J518 Wiring.pdf
Correct Door Handle Part (All Handles are universal to Left/Right, Front Back) #: 5N0837205L
pillpusher84
NJ
2015 Jetta TDI SEL Auto Scan:
Code:
Thursday,02,April,2015,19:17:45:11800
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 15.3.0.0 (x64)
Data version: 20150314
www.Ross-Tech.com
VIN: License Plate: TDI
Mileage: 5040km-3131mi Repair Order:
Scan: 01 03 05 08 09 13 15 17 19 25 2B 2E 37 3C 44 47 55 56 75 77
0B
VIN: 2015 Jetta SEL TDI Mileage: 5040km-3131miles
13-Auto Dist. Reg -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
75-Telematics -- Status: OK 0000
Part No SW: 04L 906 016 AJ HW: 04L 907 309 K
Component: R4 2,0L EDC H20 8273
Revision: 8AH20---
Coding: 01190012042410085000
Shop #: WSC 00066 790 00015
ASAM Dataset: EV_ECM20TDI01104L906016AJ 001008
ROD: EV_ECM20TDI01104L906016AJ.rod
VCID: 71E3AB66A08702B038-8024
Revision: 00H46001
Coding: A14B400C492A00FA851002EC92220042A110F01A
Shop #: WSC 00066 000 00000
VCID: 040DF2B287350718E3-8051
Revision: 00092000 Serial number: 0350998582
Coding: 030C0C
Shop #: WSC 00066 000 00147
VCID: 3777557E8E639C8036-8062
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 1K8 907 044 E HW: 1K8 907 044 E
Component: Climatronic H05 0102
Revision: 00001K02
Coding: 0010019002
Shop #: WSC 00066 000 00121
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW36.rod
VCID: 31636B66600742B078-8064
Revision: B8078001 Serial number: 78003343140390
Coding: 7B994B9A08230F0008382081240884C55286760E608510D0B0 A050022844
Shop #: WSC 53714 001 1048576
VCID: 30656E62630D4BB877-8065
Coding: 820000
Coding: 820000
Coding: 180000
Coding: 280000
Coding: 800000
Coding: 800000
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 5C0 907 572 HW: 5C0 907 572
Component: ACC VW361 H03 0043
Serial number: 09111477030081
Coding: 01004000280438
Shop #: WSC 00066 790 00147
ASAM Dataset: EV_ACCBEGVW361 001003
ROD: EV_ACCBEGVW361.rod
VCID: 66C9C83A9949D5085D-8033
5 Faults Found:
1130 - Sensor for Automatic Distance Control
C110B F0 [008] - Limited Visibility
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 142
1132 - Sensor for Automatic Distance Control
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 142
Mileage: 970 km
Date: 2015.02.14
Time: 18:31:46
1131 - Sensor for Automatic Distance Control
Freeze Frame:
Fault Priority: 4
Fault Frequency: 11
Reset counter: 142
1542 - Sensor for Automatic Distance Control
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 142
Mileage: 970 km
Date: 2015.02.14
Time: 18:31:46
1545 - Sensor for Automatic Distance Control
Freeze Frame:
Fault Priority: 4
Fault Frequency: 16
Reset counter: 142
Mileage: 970 km
Date: 2015.02.14
Time: 18:31:46
Serial number: 003LZD03LW98
Coding: 00004B33
VCID: 72E1A46AA58139A8C1-8027
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J1400020QGJ04
Coding: 303146
Serial number: 3572MSME56164D48ZZZ/
Serial number: 3582MSME2A2F4D48ZZZ9
Serial number: 3516KSME2C086D31ZZZY
Serial number: 3526KSME430E3232ZZZL
Serial number: 3556LSME5B217E31ZZZ
Serial number: 3566LSME7E337E31ZZZ4
Part No SW: 5C6 920 974 F HW: 5C6 920 974 F
Component: KOMBI H04 0808
Coding: 271A01
VCID: 336F616E9A1B70A00A-8066
Revision: B8078001
Coding: 102200
VCID: 70E5AE62A38D0BB837-8025
Component: IMMO H04 0808
Serial number:
Coding: 000007
VCID: 6AD1BC0A8D51F16879-803F
Revision: 00000000 Serial number: 14000310268002
Coding: 4100000000000000
VCID: 30656E626B0D4BB877-8065
Cannot be reached
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1Q0 035 274 K HW: 1Q0 035 274 K
Component: RNS315-NAR H85 0501
Serial number: VWZAZ2P0548332
Coding: 040900610100060000008000
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 3261646A650179A801-8067
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V7N 0060
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 A HW: 5Q0 907 686 A
Component: HRE_Master H11 0066
Serial number: 0346421740
Coding: 01011101
Shop #: WSC 00066 790 00080
ASAM Dataset: EV_HREntryHella 001024
ROD: EV_HREntryHella.rod
VCID: 3B7F494EB24BB8E0D2-806E
Lane Change Assistant 2:
Revision: 00H22000
VCID: 3973534670778AF0C0-806C
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0015834
ASAM Dataset: EV_AudioVerst10KanalSTT3 S01001
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: 2855860253DD0378AF-807D
Address 55: Headlight Range (J745) Labels: 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 081200010B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_SE36.rod
Left_headlamp_power_output_stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329
Component: LeiMo links H01 0004
Coding: 860000
Right_headlamp_power_output_stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329
Component: LeiMo rechts H01 0004
Coding: 860000
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140530
Coding: 02630102C24232007F1606000000
ASAM Dataset: EV_OCULow 002009
VCID: 142DC2F2FF55979873-8041
Revision: 1B001001 Serial number: 00007666804242
Coding: 0A100300A0010110
ROD: EV_UHVUMI.rod
End
pillpusher84
NJ
Compare 05-Acc/Start Auth. ECUs from TDI SE v. TDI SEL
See below. Both vehicles have the same exact hardware. SEL has OEM keyless entry and keyless start, whereas SE only has keyless start. See the only difference is in the coding! This leads me to believe that this should be easily added, wired and coded! I just bought a used Jetta Keyless Entry Driver's Door handle on eBay to try this out. It is the wrong color, but these don't come prepainted from the factory, so they will need to see a body shop regardless ... so best to experiment with used parts! OEM Part lists for $269.00 each
2015 Jetta TDI SE w/ Connectivity:
Code:
   Coding: 000F0F
2015 Jetta TDI SEL:
Code:
Coding: 030C0C
faultymechanics
Vermont
1992 Jetta Ecodiesel, 2015 Jetta TDI SEL
You need to find where the code f0r the remote entry is. Car probably still wont work for the door knob because you havent told the code to look for it. It is definitely possible this code isn't reachable without hacking your car also, which my guess....is illegal.
pillpusher84
NJ
Not sure what you are talking about exactly ... I assume you mean the key's unique security code, which is already registered to the J518 ECU, as it is authorized to start the engine. The only coding change to the ECU will be to tell the module that additional antennas and sensors are present in the vehicle. This is quickly accomplished via VCDS :) ... the coding comparison between the SE & SEL models posted above shows that as the only difference between the 2 models.
As far as "hacking" my car ... i own it, so there nothing illegal about me doing anything to it, it's mine ... i can set fire to it if i wish :)
Warranty coverage may be another thing ... denying warranty coverage could be the only "repercussion" to me modifying the vehicle from it's original configuration. This is not really even a consideration as the warranty is 3y/36k and I have 10k on it already since March 2015 ... so that will run out rather soon :(
Old Radar
San Antonio, TX
It looks like you may be on to something Pillpusher. Please document the piss out of your mod. I for one will certainly want to follow your footsteps should it be successful. I'm sure we are not the only ones irritated by this feature. Good Luck! Take pictures and keep us updated!
pillpusher84
NJ
I will let you know. My door handle was just shipped via a message I received from the eBay seller. I will need to get the proper wiring connector from VW as well, so I can add the 4 wires and then code the J518 with the correct byte values.
--Antonio
pillpusher84
NJ
Very eager to hear how this turns out. I'd much rather just have a key slot than this half keyless system.
Every Car that I have owned since 2006 has had push-button start and keyless entry, I can not stand this and it will be resolved soon! (hopefully). While most of the cars are a bit upstream from the MK6, the Camry and Rav4 are in the same price range as the MK6 and have had this feature standard for almost 10 years now ... come on VW!
2007 Toyota Camry
2007 Lexus GS350
2010 Lexus RX350
2010 Toyota Rav4
2010 Infiniti G37S Convertible
2011 BMW 535xi
2012 Acura TL
2014 Acura MDX
2014 BMW 550xi
Spacewalker
Poland
2.0 CR
Possible to add kessy system
Already did it in my 2005 VW
https://www.youtube.com/watch?v=b40w8xfera4
but is not easy
Let me explain you a little:
1- ELV (2B) controler must contain FAZIT (immo) data , and VW online must load it (2nd hand will not work)
2- 5th controler - must be order via VIN , because contain VIN data , and any other virgin or 2nd hand will not match with your car ...and will not allow use a Kessy
3- new KEY's , must be a KESSY kesy (similar to RF ID proxy chip). Old KEy will not work inside car, only if you place it close to "emergency start place" ... near ignition coil
After that all new parts must be match with Immo data ( Cluster + ECU)
The best Idea is to get a 2nd hand parts from donor / scrap parts
Houston, Texas
'15 Jetta SE TDI
This ridiculous keyfob out of pocket, unlock doors, into cupholder, push start, push off, remember keyfob, lock doors, keyfob into pocket... procedure... is killing me!
I eagerly await your response.
scotthershall
New England
2003 Jetta 5spd
I'm sure many people on here would be interested in having "how-to" documents on this stuff as well. I may very well be purchasing a 2015 Jetta S, and I'd certainly be interested in adding some of the SEL goodies, especially the xenon headlights!! No need to spend an extra, what, $8000 on an SEL...
Scott
LOWRANGO
Port Reading NJ
1999.5 Golf GLS TDI Auto
Interested if this worked out. Just purchased a 2016 Sport, so I have the Kessy-Go but would like to have the Keyless also.
pillpusher84
NJ
sorry ... i have the parts and never bothered to install and code it as the car will be gone in a few months given the TDI issue. I sure as hell wont let them fix it and ruin the performance of my car making it emissions compliant. Much easier to sell it back and take their money and run. The whole thing is quite a shame. What a great car otherwise!
Can't imagine that it wouldn't work, since the KESSY antennas are part of the door handle, and the KESSY ECU is the same in my SE as it is on the SEL, with different coding to indicate the additional features and parts on the SEL over the SE. Parts should simply need to be wired according to the wiring diagrams and the KESSY coded to make this work.
sorry ... will not be active on this forum any longer ... thanks to everyone who assisted me in the past with questions about my TDI SE Jetta.
Gonefishing
Kissimmee, FL
2015 Jetta TDI SE
Pillpusher84: "added an RNS-510 Navi".
I would greatly appreciate some information on this upgrade. I have I believe RNS-310, could be wrong, I want to upgrade to the 510 just not sure of the parts/pieces i need to do this. Did you happen to save any lists of what was done or how?
I have a 2015 tdi se without nav, is this a very difficult install?
Thanks for any help here.
mklabunde
Milwaukee, WI.
2015 Passat SEL Premium
yes I would like this info also. I have the 510 installed and it works but I can't figure out how to code it so I can use the voice commands. The car doesn't know the radio is installed and I get an error because of the wrong radio. please help
pillpusher84
NJ
Add navi to the gateway installation list and remove whatever radio you had there before. You will need to make a bunch of bit changes in different bytes in the navi unit, but those are straight forward once you get in there in VCDS.
MD Vet
USA
Jetta
what update you want ?
what parts did you collect and what car you have exactly ?
If installing the new door handle and re-coding w/ VCDS worked.
I am just trying to plan ahead. I'm looking at the 2016 Jetta Sport and want to know if I would be able to install "true-keyless" entry on the thing at home.
It has pushbutton start but no proximity entry.
Spacewalker
Poland
2.0 CR
Here is someone trying to do this: http://forums.vwvortex.com/showthre...Y-Door-Touch-Handle-Connector&highlight=kessy
It's looking like it's not completely plug and play.
Call "P&P" you can only if you have loom.
if not - all new wires must be pull.
Module must be code
immo must be recode
possible with programmers for immo
Proxy Key must be also , otherwise door handle will not work, and to start car you must put a key close to IMMo COIL.
to close car , key must be in range, to open car key must be in range
I know a guy in US who can code Immo + ELectronic Steering lock + proxy key
