please help with wiring loom problem
bozwell said:
nope, the car is a 1990 which makes it a CE2. everything is pretty much plug and play except theres a couple little individual wires at the fuse box that need to get powered up. for those wires i used the factory bridges that clip onto the top of the fusebox so it looks completely factory....no scotch-locks or butchered wiring here!
hi there,
was wondering if you can help me.
i have just fitted the mk3 golf tdi engine loom into my 1990 mk2 golf,
and have a few small plugs that i cant find a home for.
i initially opened up the insulation on the loom and removed all of the unecessary wiring and plugs so that i would be left with just the wiring for the engine/ecu etc. so far everything has plugged into the fuse box nicely apart from a few small plugs and one wire which come out of the black immobiliser box, and also a plug from the mk3 speedo cluster loom.
you stated above that put a live to some of the small additional plugs, do you by any chance remember which ones it was
any help or advise will be greatly appreciated,
thanks
