Spulen81
- Joined
- Mar 30, 2004
- Location
- Warners, NY
It won't fit in the stock location in my truck anyways. There is plenty of room on the other side of the engine though..
I'd bet its dieselPaddyboy said:What kind of fuel are you running on this beast? (Forgive me if I haven't read this whole thread).
Nice job btw!!!
Do you offer a kit to put a Toyota automatic trans behind the VW TDI?texasmeat said:We are currently developing a plug n play conversion kit for the ALH TDI into a Tacoma, 4runner and Jeep wranglers. PM me for more details.
I used them to mount a 2wd toyota auto to a 1.6TD. The 2wd is mechanically shifted, no electronics. Power was ok but shift points did not feel right. I ended up swapping in a 5-speedCheck out Acme Adapters
http://acmeadapters.com/
Do you still know the part number for the non-a/c water pump pulley and the new belts that you used. I am working on this same swap in a 94' Toyota pickup and I am trying to get everything organized and the engine ready to go for my swap in a couple of week. I want to avoid any issues, if you had the info for these parts to delete my a/c compressor it would help me out a lot, I have searched for an hour today on-line and have yet to find this pulley. Thanks for your time.[/QUOTE]Here are the accesories... all factory VW from the TDI, the crank V-belt pulley is a smaller one from an ABA code gasser and its way smaller. My stock one was bent so I had to make do with this one for now. Everything fits great WITH the AC deleted. The compressor would not have fit but there is a really cheap way to delete using a factory non AC water pump pulley and a shorter serp and v-belt. I used a PS hose kit from PSC to make a pressure line along with a couple adapter fittings and a new return hose. So far so good.
