Spulen81
- Joined
- Mar 30, 2004
- Location
- Warners, NY
I got the 4Runner on 9/1 and I've been working hard to get it done before the nasty weather hits. I live in upstate, NY and its creaping up quickly. I never drove this truck prior to the swap so I'm really hoping it doesn't have too much wrong with it. Its not a NY native therefore super solid. The donor engine was from a '97 Jetta TDI with 110K on it, it was missing very little when I got it. This was done with a Acme kit, they have been great with tech help, btw. I got it together and running in about 2 months, with quite a bit of research done beforehand.
I have alot of other pics during the build up but they are temporarily being held hostage by my home laptop at the moment. I will post up some of the build pictures later on and current pics with it cleaned up.
Here it is in all its glory, the paint is really faded and the other side has some dents in the 1/4 but I could care less. It will most likely be painted a flat tan color once I finish up everything.
Here is the very dirty engine and compartment. Detailing this stuff is on the short list. These pics are from a few weeks ago.. the wiring is cleaned up quite a bit now.
Starter to turbo clearance... yikes. I had to swap in a different starter for clearance. The starter will be blanketed and the exhaust sheilded so hopefully its OK. I want to do a different manifold and turbo down the road. I have an older TD t3, I might rebuild and use.
Here are the accesories... all factory VW from the TDI, the crank V-belt pulley is a smaller one from an ABA code gasser and its way smaller. My stock one was bent so I had to make do with this one for now. Everything fits great WITH the AC deleted. The compressor would not have fit but there is a really cheap way to delete using a factory non AC waterpump pulley and a shorter serp and v-belt. I used a PS hose kit from PSC to make a pressure line along with a couple adapter fittings and a new return hose. So far so good.
And the intercooler, I just saw this one on ebay and took a chance hoping it would fit. It did after some minor cutting. Its a nice Spearco unit and only $100. I sold my stock TDI intercooler for $100 so it worked out great.
Here are a couple more engine shots, again these are a few weeks old.
Its alot further along now and its going on the road today. So the maiden voyage is after work tonight.
