jackedshirt
2014 Jetta TDI CJAA push start. 172000km. Still has DPF.
My apologies for a bit of long post, but I want to give everyone as much info as I can.
1. Recently had timing belt, pump and all timing hardware replaced. Top quality parts from GermanOEM. NEVER had this issue pre-belt change BUT I don't know if this is timing related or just coincidental.
2. Vehicle has tough time turning over after long sits overnight. After initial start, vehicle fires up just fine throughout the day.
Some background info:
- frost heater is always plugged in under -10celcius
-white power service is always put in every fill up generously
-I initially thought it could battery so it was replaced after i ran into this issue. Not the cause.
-oil or fuel filter were not changed at belt change however they were changed about 5000k ago.
-Glow plugs light up and off quick as they should when frostheater is plugged in
-I cycle plugs 2-3 in cold weather always
Symptoms:
After long sits overnight, if i cycle the glow plugs 2-3 times, i still get lots of healthy sounding cranking but no turn over until i either leave it cranking longer than usual or depress gas pedal. Once started, the fire up is very rough momentarily (sputters, chugs) and she will then get to idle. Dosent not stall nor do I find I have an power or performance loss after I get driving....After getting to proper idle, everything is back to normal. Its been quite cold here so I haven't been able to try it in warm weather, but as I mentioned, this is NEW issue. A couple plug cycles in deep cold weather and she would fire up no problem.
Mechanic said he initially had fuel pump timing off when he started car after belt change and after scanning via ODBEleven, it threw a a couple codes:
I cleared these codes to see if they were thrown as they were part of the belt mis timing, and they never came back.
-P0016 - Crankshaft Position-Camshaft Position Correlation Bank 1 Sensor A
-01314 - Engine control module (ECM) No signal/communication
Intermittent
Since depressing the pedal during the cold start helps the turnover, do you guys think it could be another fuel related issue? Ice in intercooler? (bottom grills have pipe insulating foam) I don't know if its a problem from the belt job since I don't have any other issues while driving or idling.
Symptoms:
Intermittent
