Mozambiquer
- Joined
- Mar 21, 2015
- Location
- Versailles Missouri
- TDI
- 2004 VW Touareg V10 TDI, 2012 Audi Q7 V6 TDI, 1998 VW Jetta TDI. 1982 VW Rabbit pickup, 2001 VW Jetta TDI, 2005 VW Passat wagon TDI X3, 2001 VW golf TDI, 1980 VW rabbit pickup,
I have a 2005 BEW crank no start. Well, it started once, but didn't start well.
Group 13 showed -2.01,-2.01,-1.65,2.99
I checked the timing using the crank lock and pin, replaced the damaged cam position sensor, checked the cam and injector wiring harness (visual inspection) ohmed the injectors out, made sure the asv isn't stuck closed, made sure I'm getting fuel to the tandem pump (didn't check output pressure from the tandem pump yet though)
No codes besides EGR valve (it's deleted, but not tuned) and brake switch implausible signal (possibly LED bulbs)
I also inspected the crank reluctor wheel, as it appears that someone replaced the oil pan recently.
I had gotten this car in this condition In a trade. Trying to get it going now.
