2005 mk4 Jetta barely starts
Mozambiquer
Versailles Missouri
I have a 2005 BEW crank no start. Well, it started once, but didn't start well.
Group 13 showed -2.01,-2.01,-1.65,2.99
I checked the timing using the crank lock and pin, replaced the damaged cam position sensor, checked the cam and injector wiring harness (visual inspection) ohmed the injectors out, made sure the asv isn't stuck closed, made sure I'm getting fuel to the tandem pump (didn't check output pressure from the tandem pump yet though)
No codes besides EGR valve (it's deleted, but not tuned) and brake switch implausible signal (possibly LED bulbs)
I also inspected the crank reluctor wheel, as it appears that someone replaced the oil pan recently.
I had gotten this car in this condition In a trade. Trying to get it going now.
Nero Morg
OR
I assume you've done the usual like check batt voltage and that it's cranking fast and strong?
You also mentioned you checked timing at the crank, did you check timing of the cam? With a negative angle that close to zero it should still start, but is odd one is positive almost 5 away.
What about the crank position sensor?
Mozambiquer
Versailles Missouri
Yes, I checked cam and crank timing, using the crank lock and cam pin. The cranking RPM is right at 230-250 or so
Crank position sensor looks good, I didn't ohm it out and verify. I'll plan to scope the waveform on it as well as the cam sensor, as I know that visual inspections don't always catch what's going on.
Nero Morg
OR
Sounds like you're on the right path, only other thing I could suggest is to check injector lash,and I've also heard of those pressed in balls that are in the head near the injector have worked loose in the past, if I remember right they supply oil to the injectors for timing? Can't remember.
Mozambiquer
Versailles Missouri
Its been a while... I got it figured out. The injector on cylinder 4 was bad and the fuel system was getting compression in, which was keeping it from firing well.
Replaced the injector and it is running great.
Shenandoah
Shenandoah Valley, VA
2005 Jetta Wagon; 2005 Beetle; 2004 Jetta; 2002 Golf (three of them); 2002 Jetta Wagon; 2000 Audi TT->TDI; 1999 Beetle
Mozambiquer,
Thanks for the information. I have a 2005 New Beetle that developed problems in 2020 with 280,000 miles. It would start and run fine, but as soon as it warmed up it would lose power and act like it was "missing". I could turn it off and turn it on and it would run fine for a couple minutes then start missing again. Then one day, it just wouldn't start. I swapped the Crank Position Sensor, injector harness, fuel filter, etc. No change.
I've always wondered if I had a bad injector? How did you test/determine injector #4 was bad? Thanks.
Eric
Mozambiquer
Versailles Missouri
Mozambiquer,
Eric
What I did to determine it was bad is I could see with vcds that it had a misfire on cylinder 4. I checked the cam and checked for continuity on the harness. I had a spare set if injectors so I then swapped one in and it ran a lot better.
Most often its not the injectors, but this car was run on biodiesel and I believe that is part of what killed the injector.
More often the symptoms you describe are a worn cam .
Shenandoah
Mozambiquer,
Thanks for the quick reply. I'll have to take a close look at the cam again to check for wear. Thanks!
Eric
