2003 ALH doesn't start or when it does idle hunts.
Mods:
"Recent" Maintenance.
Car ran great after the timing belt. Timing was dead on. No issues. Went to Walmart about a month ago. I did some spirited driving (I hadn't been driving in a few weeks) on the way home (10 miles) and didn't notice anything. The next day I went out to start it and ... nothing.
As we say at work: Air, Fuel & At the right time. (Alternatively: Suck Squeeze Bang Blow). Checked everything and assumed it must have been timing somehow. I triple checked all the fuel (thinking it was the issue I had in the past). Give the smell of unburt diesel and hard starting I deduced it was too retarded.
So I loosened the IP bolts and turned the pump all the way clockwise (advanced timing, I 'm pretty sure). I got it started and it actually ran just fine for about a day or so. Then driving home one day I pushed in the clutch and it died. I popped it to restart and had to keep it above 1500 RPM to get it home. Then
This weekend I redid the timing. Removed the cam gear, locked the IP. I marked the belt and it looks like somehow I skipped a tooth (or it was always off).
However. Same hard start problems. Tossed on VCDS:
Setup 1)
Timing cranked all the way retarded. IP in the "original spot".
Starts, catches dies.
http://www.youtube.com/watch?v=1YptUg-Fcts
Setup 2)
Timing cranked all the way advanced. IP Hammered just a bit to the drivers side. (Camera is facing front of car). High idles around 2500 RPM. But is smooth there.
http://www.youtube.com/watch?v=wk_0h6gEP6k
Setup 3)
Timing cranked all the way advanced. IP hammered just a bit to the passenger side. Rough idle.
http://www.youtube.com/watch?v=JybeTK-RuS0
Setup 4)
Timing set about to the center. IP hammered about back to stock. Rough idle but a bit clacki-ity-er.
http://www.youtube.com/watch?v=vL8y-r_6S4w
http://www.youtube.com/watch?v=gEUFBKBHqdM
On the rough idles the IQ is all over the place.
Full scale is 10 mg/stroke. So you can see it's all over the place.
Oh, and for some reason my injectors are crazy imbalanced. (I paid extra for the balancing from DBW/Kerma)
Current theory is that when I had the air in the system a while ago the long cranking caused my pump to eat itself and the effects are just now showing up.
Mods:
- Bosio DLC 1019 (ULSD RATED) Next Generation Design
- TDTuning (vwmikel) Stage 3 Tune
- EGR Blockoff
- Simlified Vacuum Harness eliminating EGR.
- 165k - Oil Change
- 163k - Timing Belt
- 163k - Fuel Filter
- 163k - Air Filter
- P1562 "Fuel quantity adjuster upper limit reached"
Setup 1)
Setup 2)
Setup 3)
Setup 4)
