Well I sold my 1999 Cherokee with an IRO Long arm kit and 33's because it was very rusty and I was offered more than I had in the Jeep and more then I would every get out of it. I have been surfing the net for a while when I came across a nice 2000 Cherokee with what I thought was JUST a cracked 0331 head. I forked over $600 for a Cherokee that was Ziebarted and still had the original floor. The only rust I saw that needed attention was on the passenger rear rail above the rear axle. I figured it was just the 0331 head that had cracked and bought an 0630 head before I pulled it apart. Well I pulled it apart and the head was cracked but it also had damage to the #2 and #3 cylinder wall so I looked around and everyone wanted a lot of money for a 200k motor. Well I have been into TDIs for a while, my wife and I each own a 2010 TDI. So I started looking for a TDI. While he is doing that in the mean time I ordered a gallon of Olive Drab Green from Summit Racing because my Jeep came in three different colors and being a Veteran I have always loved OD (even though most of my equipment was Tan). Well the other day I came across an add for a 2000 Jetta TDI 5spd that was wrecked but it could still be driven. The guy wanted $1200. I offered him $1000 and after a 7hr round trip I was finally home with my new car. The car has 230,004 miles on it and it ran great.
This is going to be a slow build but it is more for my reference to see what I had and where it goes. The Ultimate goal for the Jeep is OD Green, I want to add a turbo, injectors and I'll be using a Taco Taco SMIC to hopefully get this TDI close to 180hp. May 22-25 a local LKQ pull your part is having a 50% so and they have a 4.10 geared HP 30, so if its still there I'll be pulling that and 4.10 Ford 8.8 to swap into the Jeep and for both axles I will be under $120. I am also going to install an IRO 5.5 Long arm kit since I HAVE to lift it to clear the motor.
Here are some pics for your viewing enjoyment.
I decided I was going to do a FULL color change so I stripped the engine bay and started to degrease and sand the engine bay.
