GTiTDi
TDIClub Enthusiast, Macht Schnell! Vendor , w/Busi
- Joined
- Oct 18, 2010
- TDI
- '91 GTI CJAA swap,'02 Jetta wagon ALH swap, '03 GTI 1.8T rally car, '03 Sprinter 3500
thread from the dead!
Or you can just simply disconnect one of those single wire blue connectors in the right of the pictures. Once you figure which of the 3 it is, you can mark it for later.Yes, on the back of the fuse panel you will find two blue electrical connectors that have all white wires going into them.
Look up where the connector is on the CE2 diagram.
Find wire U2/2 and either cut it like other people have, or remove it from the terminal and install it on a switch. I put mine on a switch so I could still use the cruise control when I wanted.
None of the cluster wires Abacus et al is talking about connect to those junction blocks so no, the blue block and connectors are a different situation.Or you can just simply disconnect one of those single wire blue connectors in the right of the pictures. Once you figure which of the 3 it is, you can mark it for later.
Trust me, it is the blue block and single wire connectors you want. http://forums.tdiclub.com/showthread.php?t=286509None of the cluster wires Abacus et al is talking about connect to those junction blocks so no, the blue block and connectors are a different situation.
The white wires in the cluster harness go directly from fuse box to the cluster without interacting with anything else although there are a couple exceptions to that. The wire in question at U2/2 will need to be disconnected from the big blue fuse block plug, or at least that's about the easiest spot to get to it. I suppose you could remove it from the other plug at the cluster too.
Steve
I was able to manipulate IQ and injector balance to control my shudder for a few years. There is something that wears out (valve guides?) and it cause the shudder to get worse with time.I had to play with the IQ a little bit. Disconnecting the VSS in my case was making it worse. I had the shudder in all of the gears almost. Hammer moded the IQ to 5.2mg/R and looks like it liked it, the shudder in low rpms stopped.
I'm sorry, I misread what was there, yes, the VSS can be disconnected via the blue block single connector but you have to figure out which one it is. The connection that gets it to the cluster harness is done internally at the fuse box at W1 and routed out through U2/2 to the cluster.Trust me, it is the blue block and single wire connectors you want. http://forums.tdiclub.com/showthread.php?t=286509
Don't let what you read in books lead you astray.
This shuddering problem happens mostly with tuned 1Z so the 1997 Jettas have this problem also. Disconnecting is not a cure. It is simply a band-aid and leads to other problems in low gears for some people. Disconnecting the VSS from the ECU turns back the injection timing. I would say the root cause is worn valve stems or to much timing advance.
see post #18I'm going to bump this up. I found this thread while trying to diagnose a stumble on throttle tip-in in my AHU swapped audi. It has a tune and big injectors. Runs great, but stumbles mildly when warmed up and under very light throttle conditions. I'v wasted quite a bit of time trying different IQ settings to no avail.
I disconnected the speed sensor, and the car runs PERFECT. I wanted to keep my cruise control so I used a relay that has the signal powered off of the 12v+ from my "cruise on" switch. This relay is used to connect the VSS to the ECU when the cruise is switched on, so cruise will work. If you switch off the cruise, the signal is disconnected and the stumble is avoided.
You never are really at light throttle at low speed when using cruise, so this seems to have completely solved my problem.
yes, exactly.I'm guessing you used a standard Bosch style relay? Is the wiring below, correct?
85 ground
86 12v trigger from cruise stalk
87 one side of VSS wire
30 other side of VSS wire
-Todd
doh!!see post #18
Don't know the answer to the replacement VSS question, but I can certainly answer the fuel gauge question.When I unplugged the VSS I also got the flaky fuel gauge. Dose this problem continue when it is rewired with the switch?
