TurbinePower
You two crack me up.
Did you try painting your axles?
yep repainted the other one and touched up the oil pan!!TurbinePower said:You two crack me up.
Would a battery thats only 9.25 inches, or 10 inches help? The Optima's come in both of those lengths.AWPGTI said:My current battery is 11"x7" the width is fine it's the length that is the issue......I'm sure that is a common issue for you Ron haha
AWPGTI said:silverstar which optima are you running
Not all batteries are created equally...rackaracka said:Will a small battery still have the CCA's to crank over the engine on cold winter nights?
whats ah? amp hours?oilhammer said:Actually, Optima batteries generally are not well suited for these because they generally have a lower Ah rating.
That seems to have worked for tens of millions of cars. Heck, they are STILL building these cars!compu_85 said:Personally I'd just use the factory oil filter and factory battery location
-J
Exactly...and it could be reverted in the future if you run into power problems.AWPGTI said:i see no reason not too
